Keep & Kill
....1
GRAYFEATHER (71), vonriken (70), The Crusher (63), madisonlink (60), hillbilly (59), mardyk (56), Blade (54), dmraco (51), jmcclure (44), Ryand36330 (43), nrrs (43), CRB1006 (33), Yoitsjustin1 (21) |
20th April 2013
Posts: 7,431 Sportster/Buell Model: 883 Xl Sportster/Buell Year: 1992
what stator & rotor brand?
I need a new rotor & stator. Any after market ones that are superior or junk? Or stick with factory. Do the rotors come with the sprocket attached? Thanks Ryan o Ya....I sheared the bolts that hold the sprocket to the rotor. Not pretty.
20th April 2013
Manual says I need new screws with special loctite? What's the secret?
21st April 2013
here is a pic of a 1993 and mine 92, the mounting bolts are different.
21st April 2013
Posts: 6,841 Sportster/Buell Model: 1250 Hammer Hugger Sportster/Buell Year: 1997
Wow!!! If the bolt pattern is the same, could you countersink the 93?
George
--Thomas Jefferson
21st April 2013
Posts: 8,549 Sportster/Buell Model: XL1250S Sportster/Buell Year: 1998 Other Motorcycle Model: Yamaha MT-09 Other Motorcycle Year: 2016
A couple of years ago I replaced a (stock, 13 year old) stator and regulator, using a Cycle Electric Inc stator and an Accel regulator. The regulator went south a few weeks ago and I replaced it again - this time with one from Cycle Electric. Their gear is a lot more expensive, but they have a good reputation, and I'm willing to pay for peace of mind.
Are you stripping your gearbox to check for damage?
21st April 2013
Using new screws is insurance against this kind of thing happening. The screws come pre-coated with Loctite.
Rotor and pulley are sold separately.
21st April 2013
The 93 wont work because the magnets are broke out of it.
21st April 2013
Thanks for the info
21st April 2013
ok, thanks again. The screws were still in just fine. I see they sell new ones to use. This wasnt the cause of the damage. I dont know if the magnets broke then caused the 4 bolts to shear off or the 4 bolts sheered off first, as in the bolts that hold the sprocket to the rotor.
I pulled the tranny and everything looks ok, mainly just some copper wire chewed up. Thanks steelworker.
21st April 2013
A Million Facts & Figures
Posts: 10,279 Sportster/Buell Model: XL883 Sportster/Buell Year: 2007 Sportster/Buell Model #2: Buell Cyclone Sportster/Buell Year #2: 1999
Ryan, those 4-bolt units used to fail a lot on Buell tube frame bikes. They're fine on stock XL's but they fail a lot on high power bikes. HD finally upgraded it to a new 8 bolt design in like 2001ish if memory serves. Ditto the chain tensioner, the steel backing up the plastic shoe was about doubled in thickness around the same time due to failure issues in Buells.
Anyway, I have a good 8-bolt unit I'd sell you for half the cost of new. Either that or you could go aftermarket ... there's an encapsulated magnet design that comes out of Taiwan, nice piece, sold under a handful of different brand names, lists for $179.95 less your discount.
