0 Engine dies when choke off
Last Post: ChicagoSlim
0 Help please...77 xlch oil line routing diagram image?
Last Post: 69sscamaro
0 Won't rev past 1200
Last Post: Aocasio
0 Oil use/smoking
0 Speedo cable lube
Last Post: a150bdriver
Last Post: Hank21113
Last Post: halfmt1
Last Post: Edster
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 Head gaskets.
Last Post: sltm1
0 newby from Australia
0 blonde, brunette, red?
0 Dynamic timing the 2000i?
0 too bad
Last Post: robistro
Last Post: Crosshairs
0 seeking advices
0 Cream
Last Post: jakewalter
Old 10th July 2013
totaldismay totaldismay is offline
Sportster/Buell Year: 1971
totaldismay is an unknown quantity at this point
Default how do i time my 1971 sportster
i have a 71 sportster that im trying to time. there is a single dot and a line on the flywheel. i keep trying to time it off the line but it is either totally advanced or totally retarded when i do this. the only this that has changed is my points were gapped wrong so i re gapped them to .018 and this is what i have been coming up with this for timing
Old 10th July 2013
The same way you time most any Harley.
http://xlforum.net/forums/s...d.php?t=231711
Old 11th July 2013
that is the video i used for the results that i came up with
Old 11th July 2013
Mosey Mosey is offline
Sportster/Buell Year: 1982
Other Motorcycle Model: FX
Other Motorcycle Year: 1976
Ya can't assume that ya have the original flywheels in the cases. You need to determine TDC with a plastic straw through the sparkplug hole. Don't use a screwdriver or pencil or the like, trust me!. Then match up yer flywheel marks.
Are you timing with a light or static?
About the changed flywheels - my '76 Shovel has flywheels from a '38 ULH. Ya hafta verify if ya haven't owned the bike from new...
Old 11th July 2013
static timing. which cylinder do i want the piston to be at the top of
Old 11th July 2013
Pan55's Avatar
Pan55 Pan55 is offline
Sportster/Buell Year: 77
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 77
Other Motorcycle Model: 1978 FX Shovelhead
Pan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to beholdPan55 is a splendid one to behold
front cyl.....compression stroke...( front intake will be closed, and you will feel* pressure blowing out of the spark plug hole )
Old 11th July 2013
piniongear's Avatar
Other Motorcycle Model: FXDL
You need to be running the engine at about 1800 to 2000 rpm when you use a timing light.
The reason being...... that rpm is needed to make the advance weights 'fly out' to the fully advanced position.
At that point the slash mark will appear in the timing hole using the light.
Also, your points gap should be set at .018 before you begin the timing exercise. A different gap will change the timing.
You can get the mark dead center if you want, but as long as the mark is seen anywhere inside the timing hole, the timing is close enough.
pg
Old 11th July 2013
Sportster/Buell Model #2: xlh
The Doctor71 is a splendid one to beholdThe Doctor71 is a splendid one to beholdThe Doctor71 is a splendid one to beholdThe Doctor71 is a splendid one to beholdThe Doctor71 is a splendid one to beholdThe Doctor71 is a splendid one to beholdThe Doctor71 is a splendid one to beholdThe Doctor71 is a splendid one to beholdThe Doctor71 is a splendid one to beholdThe Doctor71 is a splendid one to beholdThe Doctor71 is a splendid one to behold
+1 on what the others have said.......
The rest of this might be on the edge of too much info:
For a '71 with stock flywheels:
  • vertical bar → | ← = 45° BTDC on front cyl
  • vertical bar → | ← also = TDC on rear cyl
  • single dot → • ← = TDC on front cyl
  • double vertical dot → : ← = 45° BTDC on rear cyl
but only you can determine if you have a stock '71 flywheel.
With a typical dual fire coil & if you've done a great job setting the point gap & the timing, your timing light will show BOTH the vertical bar | and the double vertical dots : overlayed in the timing hole window...... aka they'll both appear to be in the window at the same time.
Old 11th July 2013
shovithead's Avatar
shovithead shovithead is offline
Sportster/Buell Model: XLH XLCH
Sportster/Buell Year #2: 65
Other Motorcycle Model: XLCH
Other Motorcycle Year: 68
shovithead is a glorious beacon of lightshovithead is a glorious beacon of lightshovithead is a glorious beacon of lightshovithead is a glorious beacon of lightshovithead is a glorious beacon of lightshovithead is a glorious beacon of lightshovithead is a glorious beacon of lightshovithead is a glorious beacon of lightshovithead is a glorious beacon of lightshovithead is a glorious beacon of lightshovithead is a glorious beacon of light
You probably know this, but you have to advance the points cam to full advance, to get it static timed correctly.
Keeping the Old Iron, on the road for another generation to ride.
Old 11th July 2013
I use a small 12mm wrench to hold the points cam in the advanced position when checking timing.
