Last Post: jammantoo
0 Value of a Boattail?
Last Post: valvebeater
Last Post: lugster
0 Viking bags??
Last Post: cotton1
0 Stock 883 cold blooded
Last Post: Diogenes415
Last Post: lugster
0 2001 883 'customizing' log
Last Post: cotton1
0 rpm jump pulling in clutch
0 79 ironhead
0 Not charging issue!
Last Post: lugster
Last Post: jordan1200
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
0 79 ironhead
Last Post: Steven2142
0 1967 XLCH stroker project
Last Post: Keithybloodygeorge
Last Post: Turbo Sporty 48
0 Feeling in trouble.
Last Post: gravydog
5 Am I looking for Trouble ?
Old 20th February 2008
sportsterbob sportsterbob is offline
Sportster/Buell Model: hugger
sportsterbob is an unknown quantity at this point
Default sportster clutch
cannot get clutch adjusted on a 2001 sportster.i have manual,ive done everything by the book.but still no clutch.
williamv1203's Avatar
williamv1203 williamv1203 is offline
Sportster/Buell Model: 1203 XLH/Buell Hybrid
Sportster/Buell Year: 1988
Other Motorcycle Model: FXDWG TC88
Other Motorcycle Year: 2000
williamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to behold
Question Clutch
Is the cable completely slack?
WE NEED MORE DETAILS!!!
langner91's Avatar
langner91 langner91 is offline
Other Motorcycle Model: FLHTC - Finally!
Other Motorcycle Year: 2008
langner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the roughlangner91 is a jewel in the rough
A lot of times, the bike sits for a few weeks because it is cold and crappy out and then you think the clutch is stuck when you pull the lever and can't roll the bike around in your garage.
Is this what is happening?
If so, put her in neutral, fire it up, let it idle for a few seconds, pull the clutch and give her a pop into first. You might want to put the front wheel up against something firm, just in case.
~Corey
i just got the bike back from the shop[H-D shop]new front end & bars.would not even pull in my garage.and now they say its on me,so i bought a manual and adjusted it 5 times so far.still no luck
Did you ride it back or was it delivered/trailered?
You need to tell us a lot of stuff at once, not just a bit here and there. Tell us from the start what went on from when it left your possession til you got it back with the clutch problem and whether... things like the lever flops in and out or whatever...
it was delivered
it ran fine when i put it in the shop,its only got 5000 miles on it.when i got it back i rode it around the block,it ran fine.i shut her down tipped the delivery dude and went in the house for an hour or so.i came back out to put her up for the night.and had no clutch,no slop in the lever or cable.it was in gear when i tried to start it.so i pulled in the clutch and it just lurched.i put it in neutral and fired her up.she sounded good,so i tried first gear,it lurched forward and died like i didnt have the lever pulled in.
Hot Rod Sporty's Avatar
Hot Rod Sporty Hot Rod Sporty is offline
Hot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud of
Did they change your clutch cable?
Did they have to disconnect the cable from the clutch at all?
I'm assuming that you still have pressure on the cable...so it's not likely that the cable just came loose inside the clutch cover...
Did you try opening the derby cover and making sure everything is still hooked up properly?
________________________________________
PROUD MEMBER OF THE 'IGNORED BY '79' CLUB :banana __________________________________
[SIZE="1"][B]RIP James "Mr. Jimi" Melton - 1947-2008
Godspeed brother.[/B]
[B]"Dream as if you'll live forever. Live as if you'll die today."[/B] --James Dean
[B]"A narcissist is someone better looking than you are."[/B] --Gore Vidal
[B]"I just love the 'mechanicalness' of it"[/B]
--Indian Larry Desmedt[/SIZE]
no new cables,ive had the derby cover off 5 times.and everything looks fine and is still hooked up.when i pull the lever in the ramp and ball still moves so i assume the cable is still good.
Did ya pull the ramp out and make sure all the balls are there and in their slots?
Is the ramp moving outward as it turns?
