0 Paulie420 needs your help.
Last Post: Paulie420
0 1977 Bright Blue
Last Post: Airarbiter
0 THE Trainspotting Thread
0 Brake Squeek
0 Won't rev past 1200
Last Post: Aocasio
0 Mikuni HSR42
Last Post: jammantoo
Last Post: Keep it running
Last Post: RandyMac
0 Not charging issue!
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
Last Post: felis
0 Where did it go?
Last Post: mwXL 2006
0 z bars
Last Post: Bryan83taco
Last Post: The Crusher
0 2001 883 'customizing' log
Last Post: Jheitt
Old 18th July 2013
tizard tizard is offline
Sportster/Buell Model: 1966
Sportster/Buell Year: xlch
tizard is on a distinguished roadtizard is on a distinguished road
Default 66 xlch clutch sprocket; ratchet gear rivets
gee, i have to take the rivets out of my clutch sprocket to repalce the stablelizeing washer,,what is a way i can do it with nothing but a drill,,,i am trying to cut costs, i am takeing it to the machine shop to put new ones in it but maybe i can save a bit if i can get these out myself,,thanks very much and what side are the rivets factory side?? again thanks ten times ten..
Old 18th July 2013
randy3934's Avatar
Sportster/Buell Model #2: 1979 and 1969 XLCH
Other Motorcycle Model: FXE Superglide
Other Motorcycle Year: 1980
randy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud of
the rivets are kind of nail like, the heads are on the ratchet side, center punch them and drill with a bit slightly smaller then the heads, go slowly until the head spins off, if your re using the ratchet ring try not to drill into it. drive the remainder of the rivet out from the ring gear side with a suitable drift pin.
I'm not a complete idiot, some parts are missing.
Old 18th July 2013
Default gravy on the bread;
thanks,i will try this later today; my bike don't have a ring gear though,,kick only,,,gravy on the bread,,,thanks
