Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle - Bottom End
0 first harley- help!!
Last Post: rickthrash99
Last Post: lo-rider
0 project 74 sporty
Last Post: CaptEvo
Last Post: cotton1
Last Post: The Crusher
0 Engine dies when choke off
0 Feeling in trouble.
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 newby from Australia
Last Post: philipml
0 Cylinder Piston kits
Last Post: chevelle
Last Post: Don Biter
Last Post: blindfredy
Last Post: felis
0 fuel in the oil tank
Last Post: Sadsack
Last Post: Ben221
5 Am I looking for Trouble ?
0 Nighster seat on Iron
Last Post: BSA Bob
Last Post: Screw Loose Dan
5 Transmission HELP!
Old 26th July 2013
tkcustomcycles tkcustomcycles is offline
Sportster/Buell Model: 883xl
Sportster/Buell Year: 1990
Other Motorcycle Model: custom softail
tkcustomcycles is a glorious beacon of lighttkcustomcycles is a glorious beacon of lighttkcustomcycles is a glorious beacon of lighttkcustomcycles is a glorious beacon of lighttkcustomcycles is a glorious beacon of lighttkcustomcycles is a glorious beacon of lighttkcustomcycles is a glorious beacon of lighttkcustomcycles is a glorious beacon of lighttkcustomcycles is a glorious beacon of lighttkcustomcycles is a glorious beacon of lighttkcustomcycles is a glorious beacon of light
Default 1990 4sp oil pump
Wondering if anyone has upgraded their oil pumps. We have a 1990 xl that has been modified to an 89ci S&S stroker. Would like to have better flow and scavaging.
Any thoughts would be appreciated,
Thanks, Kirk
Old 26th July 2013
norseXL's Avatar
norseXL norseXL is offline
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1994
I routed the oil from the relief valve in the filter housing directly back to the oil tank on mine, now it no longer dump it into the cam chest.
Never seen it be done before so I will take credit for that
Have been runnin' it like this for years without issues.
Have a pic in post 14 in this tread:
http://xlforum.net/forums/s...ing+oil&page=2
Old 26th July 2013
90sportster's Avatar
90sportster 90sportster is offline
Sportster/Buell Model: 883/Hammer 1250
90sportster has disabled reputation
I put in an, 07 buell oil pump(better scavaging) and drive gear.
I believe the 07 sportster oil pump is the same as the Buell, but comes with the correct fittings.
you will also have to tap a 1/8"NPT hole for a 90*fitting into the bottom of the case.
I can snap a pic. of mine when I get home from work today.
Seems to be working well.
Disclaimer: What I say is based on my knowledge and experience only. It's entirely possible I'm full of shit. You've been warned!!
HAMMER PERFORMANCE:
1250 kit w/30* reverse dome pistons
SMASH CNC Head Porting Service on 883 Heads
Air Hammer 'CRUSH' A/C
Billet Intake Manifold
Sledge Hammer Pushrods
ANDREWS: V4 Cams
S&S: Lifters
MIKUNI: HSR42 Carb
DYNATEK: D2KI Ignition
RB RACING: LSR 2-1 Prostock Exhaust
'07 BUELL: Oil Pump & Bronze Drive Gear
ZIPPERS: Billet 4 Speed Trap Door
PROGRESSIVE SUSPENSION:
Springs up Front & 430's on the Rear
RICOR: Intiminators
SUPERBRACE
HHI: 6 Piston Front Brake Caliper
And the list goes on
Old 26th July 2013
90Sportster, thanks for the reply. Do you know the part number for oil pump and drive gear? I have #26357-02B for pump & #26391-06 for drive gear. Yes if you take picture of your setup that would be awesome.
NorseXL, I will take a look at that thread, thank you.
Old 26th July 2013
The bronze drive gear I purchased from Hammer Performance. Says fitment is for '91+ but also works for the '90.
I will have to look up the part # when I get home from work.
Purchased from New Castle HD online.
Old 26th July 2013
That would be awesome man. Thanks a ton
Old 26th July 2013
a 4 speed crank uses the same oil pump drive gear as a 5 speed crank? Or does that only apply to a 1990 as I think that was a transition year for the cranks?
Old 26th July 2013
Yep. Matched up perfectly.
Sent from my DROID X2 using Tapatalk 2
Old 26th July 2013
Can somebody confirm if this only is for 1990 models as all my books show that it should only work on 1991 and up 5 speed models so wondering what year the change really happened.
Old 26th July 2013
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
It's the same part number back to 1988. 86-87 use the splined shaft.
Click Here to Contact Me
