0 wavers
0 Rear lights
0 ultima install without VOES
Last Post: supermotolew
0 Basket case
Last Post: Parker 1000
0 Member "Wedge" Heads for 1275 Conversion
Last Post: seajay
0 Coil Resistance Question
0 Rear wheel alignment
0 Fuel Sputter & Much More
0 is a buell a harley
0 tachometer on 2012 Custom
Last Post: MDT
Last Post: vferdman
0 Anyone using the V&H FUELPAK FP3 currently?
Last Post: SwissXL
0 Sissy bar with HD quick release bracket
Last Post: JohnAkaB
0 900cc Cylinders
0 Remember these?
0 low rpm problem
Last Post: XL1275
0 Runway 06 C
0 Hagerty Insurance
Last Post: trappnman
Last Post: Bow only
Old 4th September 2013
painterdude923's Avatar
painterdude923 painterdude923 is offline
painterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to behold
Default transmission mainshaft bearing
Hey all! I have an 03 sportster 1200 custom. 73000 miles and my mainshaft bearing went about a week ago. since took trans out and 5th gear came out with the trans. just fell out! bearings fell out too! part of the bearing was still on 5th gear main and the other is still pressed in the case. I have got the clip out next to the bearing, there is not much bearing to push out! very thin on the inside of the case to push on to get it out. any ideas?
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
I would use a 3 jaw puller to get it out. As you said it comes out on the final drive side (right).
It's not super tight in there but you want to pull it out straight.
You may already be thinking this but I would change every bearing in the trans while you have it out.
Ant metal from the failed bearing would have cause damage already.
Gear1200 Gear1200 is offline
Sportster/Buell Year: 1988
Gear1200 has disabled reputation
Hi, hopefully you have some manuals as a reference, if the bearing won't come out easy,you can use a propane torch & apply heat around the bearing area to expand it a bit (don't keep the flame in one spot & have gloves, object/tools to push the bearing out before hand) or you can put in the oven @ 350 for 10-15 minutes or so. (I am a TIG welder & the company I work for is ISO 9001, aluminum is my job) good luck and I hope you get runnin soon!
Old 6th September 2013
I made a 75mm piece of 3/8 round stock with a hole drilled in the center and used a slide hammer(very lightly) and the rest of the bearing came out easily. still need the replacement bearing to install and get this bike back on the road.
Nice! I just helped my brother replace a clutch hub bearing in his '96 1200 custom. Put the new bearing in the freezer for 10 minutes & used the old bearing to seat it, since I don't have a press at home yet.. I hope you can find a bearing & get back on the road soon
Old 8th September 2013
I am also going to be replacing the clutch hub with a brand new one. do I need to replace the clutch hub bearing when I am in there? or do you think the original bearing will be fine?
Old 9th September 2013
The bearing for his '96 was $23 from J&P cycles, he needed his done. The right thing to do is just replace it especially since you're already in there. Most bearings get damaged upon removal. It's peace of mind knowing that the bearing is new and will be trouble free for the life of the bike. Sorry to hear you gotta replace the hub!
1988 XLH 1200, built.
Its all good seems how I have already put a few grand into it with hammer 1250 kit and hammer ported buell xb heads. I might as well upgrade/replace everything! I am going to be putting over 100 horses to the ground! just missed out on one of the best summer weather I can ever remember in MI.
That does suck, I know how you feel! I know what it's like when the bike just seems to gobble up the money, but a new bearing is always money well spent! Hopefully there will be no more issues after this and you can just start ripping up asphalt! Haha
Post no Avatars!
As I mentioned before, I would replace every bearing in there since you most likely had metal pieces floating around in there for some time.
I had a transmission issue many moons ago and Baker fixed the transmission but about a year later I had other bearing failure that I know was caused by the original issue.
