Last Post: Aden
0 THE Trainspotting Thread
0 48 Handling
Last Post: 201648Rider
0 Mid's or rear sets
Last Post: gusm2
0 Blow thru setup
Last Post: Sideshift92
0 -75 ironhead, My first HD
Last Post: blindfredy
0 91 oil in cam cover
0 Safe to run 2 master links?
Last Post: Reverend G
Old 14th November 2005
Robohead's Avatar
Robohead Robohead is offline
Sportster/Buell Model: 1200
Robohead will become famous soon enoughRobohead will become famous soon enoughRobohead will become famous soon enoughRobohead will become famous soon enoughRobohead will become famous soon enoughRobohead will become famous soon enough
Default Stripped threads in primary cover
Hey Guys and Gals, I'm new to the board here. I have 2000 XL1200C. I bought a new HD logo derby cover the other day. I installed it last night. No problem there, but when I went to put the 4 torx bolts back in, the bottom one stripped out. I did not over tighten it, it just gave out very easily. This is the hole that is stripped, not the bolt. So my question is.....what are my options? I don't want to replace the entire primary cover if I don't have to. Can the hole be drilled bigger and tapped and then insert a sleeve that would fill the gap? I did this years ago when my VW bug blew out the spark plug hole threads. I have no idea if it can be done on such a small scale though. Are there any other options out there? It is leaking right now, so I'm not riding until it's fixed. Any advice would be appreciated. TIA
Ron
bshadbolt's Avatar
bshadbolt bshadbolt is offline
Other Motorcycle Model: Suzuki GSX750ESG
Other Motorcycle Year: 1989
bshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura about
Hi, welcome aboard.
I am sure you can get thread inserts for this. I hear it is quite a common problem. It will entail drilling, tapping and insertion of a thread insert.
Cheers,
Brett
'05 XL1200R - Pearl Yella
Motor: N4 cams, Python 2-1, Mikuni HSR42, RamFlo 400, TC88A Ignition
Handling/Comfort: Mustang Daytripper, Progressive 418HD's, Progressive fork springs, floating brake rotors, fork brace, 1200S bars
Aesthetics: chin spoiler, bikini fairing, front signal relocation
Heli-Coil is the one i hear about the most.
What you might try tho first is to just run a same-size tap in the hole. Sometimes i have found in these cases there is still enough threads, once repaired, to hold the bolt. Then use a new bolt, with blue LokTite, tighten just to firm.
Turbota's Avatar
Turbota Turbota is offline
Get a self tapping screw ... easy
04 XL 1222R
woody95's Avatar
woody95 woody95 is offline
Sportster/Buell Model: 883/1200 Hugger
Sportster/Buell Model #2: 883 Custom
woody95 has disabled reputation
Get rid of the torx bolts and get a good set of stainless allen bolts. I've had my derby cover offf so many times I stripped the heads on the torx long ago and had to drill and use an easy out to get them out before I replaced with the stainless.
Bob
bplinson's Avatar
bplinson bplinson is offline
The XL Forum Host
Sportster/Buell Model: 883>1250 Stage 2
bplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond repute
One word....Heli-coil.
AMA #961454
xlhflh xlhflh is offline
Sportster/Buell Year: '00
Other Motorcycle Model: FLH
Other Motorcycle Year: '72
xlhflh is an unknown quantity at this point
Same happened to me on my '00 XLH. When I inspected the threads I found the only the first 1/4 inch was stripped and that I had a full inch of threads in the hole. Longer screws did the trick for me.
Hope this helps.
Ride Safe
Bob
'00 XLH1200, SE/K&N A/C, CS bologna cut muffs, mini-apes, LePera Maverick saddle, and lots of shiney stuff.
Bill2's Avatar
Bill2 Bill2 is offline
Bill2 has disabled reputation
Theres even a easyer way, get you some peratex striped thread repair compond. It comes in a two part epoxy type stuff that you mix together and put it in the stripped hole, then there a releaseing agent that you put on the screw. Then after putting the releaseing agent on the screw, screw it in. then wait about ten mins. Then you can unscrew it and the stripped threads will have reformed. Just don't tighten the shit out of it, just snuge it up a little thats all it takes!
Old 15th November 2005
Robohead's Avatar
Thanks for all the suggestions. The threads were far to gone to re-tap. They actually came out with the bolt when they stripped. After seeing the first response, I went down to Autozone and found a 'fix-a-thread' kit. It came with a 1/4" heli-coil insert, a tap and a coil installation tool. Cost $19. All I had to do was drill out what was left of the existing threads, tap the new hole and install the heli-coil. Took 10 mins and worked like a charm. I do like the idea of replacing the torx bolts with allen bolts. That's next on my list. Thanks again for all the input. This is definitely the place to go for answers.
gvd883r gvd883r is offline
gvd883r has disabled reputation
my threads stripped also, longer 3/4" length bolts worked for me.
