0 Newbie CV rebuild
0 1977 xlch starter issues
Last Post: datimm09
0 no rear brake light
5 Transmission HELP!
Last Post: Twistedrench
0 Reflectors...Yeah, or Neh
Last Post: kap
0 Drive Chain Adjustment
0 Primary Chain Adjustment
Last Post: sltm1
0 Tachometer drive
Last Post: sleighcrane
0 2016 48 Hesitating
Last Post: Screw Loose Dan
0 1968 XLCH Oil Leak
Last Post: ktskaggs1
Last Post: tvon
Old 22nd September 2013
Rioo's Avatar
Rioo Rioo is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: Triumph Street triple R
Other Motorcycle Year: 2009
Rioo has a spectacular aura aboutRioo has a spectacular aura aboutRioo has a spectacular aura aboutRioo has a spectacular aura aboutRioo has a spectacular aura aboutRioo has a spectacular aura aboutRioo has a spectacular aura aboutRioo has a spectacular aura aboutRioo has a spectacular aura aboutRioo has a spectacular aura aboutRioo has a spectacular aura about
Default Tappet guide oil leak
Hi everyone,
There is a oil leak under the front intake tappet guide of my ironhead. I pulled out the tappet guide and changed the o-ring but the leak is still here. I've noticed that the tapet guide was loose in the crankcase hole. This hole seem to be worn out. But what can I do? Can I make a quick loctite gasket to put under the tappet guide ?
thk
trappnman's Avatar
trappnman trappnman is offline
Sportster/Buell Model: XLCH- old school chop
Sportster/Buell Year: 1973
Sportster/Buell Model #2: 1981 XL
Other Motorcycle Model: Norton HighRider
Other Motorcycle Year: 1971
trappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant future
those leaks are a bugger to get rid of- the 81 has those and I hate em. if someone has a truly remarkable tip, I'd be all ears.
I drilled the oil holes in the tappets to the next size as per a tip I once read, and that helped a lot. silicone doesn't do much good, but after replacing her cams I had one that leaked with new o-rings, so we made a gasket for between the case and guide, and used the brush on red gasket sealer, and that seems to have stopped the leak
I liked the old style better, they were more of a pain to remove, but they didn't leak.
CHOPPERS MC S.E. MINN- Chopper for Life- "Old School" Steve Gappa on facebook
Rioo's Avatar
Thank trappnman.
You drilled all the tappets? What kind of red gasket did you use?
Monte03's Avatar
Monte03 Monte03 is offline
Sportster/Buell Year: 1969
Other Motorcycle Year: 82
I just went thru this last week, I cleaned up the surfaces with Brake Kleen on a rag, Install a new O Ring, with the Tappet Base on It's Back add a Bead of Ultra Copper Hi Temp RTV from the O Ring to the flat of the base, not too much-just enough to cover, Install the Tappet and Base, lock it down with the hex bolt and leave it Overnight.. just did 125 miles yesterday, the repaired Tappet base did not leak..
http://www.permatex.com/products-2/p...t-maker-detail
Cycle World Oct 1962:
Rioo's Avatar
Hi Monte03,
I can see I'm not alone ;-) When you say "add a Bead of Ultra Copper Hi Temp RTV from the O Ring to the flat of the base" it is all around? How thick is your permatex product? I've got loctite quick gasket paste http://www.halfords.com/webapp/wcs/s...egoryId_255217 .. This black paste is thick , do you think I can use it?
Thk
Monte03's Avatar
Originally Posted by Rioo View Post
Hi Monte03,
Thk
I swear by the Ultra Hi Temp that I added the link for, I use it to line the ID of exhaust flanges to seal leaks, when I say Just Enough, I'm not a Fan of Adding anything Silicone to a Motor so some Common sense needs to be applied here, the underside of the tappet base flat is not near any oil passage so I went for it, the Ultra Hi Temp is on the thick side, not runny and nasty as what we Cal Black Permatex.. the key is to let is set over night or 24/hrs
Yes-All Around where the Round section of base meets the Base Flat, once bolted down that Ultra will compress- JUST ENOUGH SIR
Rioo's Avatar
Thanks for your advice I bought the permatex ultra cooper i'm going to test that this weekend.
Old 23rd September 2013
trappnman's Avatar
well good luck on the silicone- while I use it and like it for other applications, for whatever reason even though I've tried it multi times on tappet block guides, cleaned off and dried off well- it never really seems to provide a tight seal
yes, I just reamed out the original drain holes a tad- this allows the oil to drain faster down the pushrod covers. Read it in one of the EasyRider tech books
its just high tac gasket sealer- NAPA sells it under the Permatex brand and I made a gasket out of gasket paper- hard one to made as back edge is so narrow, let it set on the case side, then installed guide, sealant on both sides of gasket
Rioo's Avatar
Thanks trappnman, what gasket paper did you use? thickness?
trappnman's Avatar
now that I don't know- not the real thick rubberized type, more the thin paper kind
