0 The KTM Duke That Started it All
Last Post: TowPro
0 hmmm, whaddaya think? (Footpeg Location)
Last Post: 45Brit
Last Post: fafcpa
Last Post: bklyngeezer
0 Check this one out for sale in the UK
0 Improving Fuel Mileage
0 first xlch
0 1999 S upgrades
0 Forest Lodge & Campground Mairenville, Pa.
0 2021 HDs now Out!
Last Post: 45Brit
0 1977 Shift shaft
0 Xl 1000 1979
Last Post: Andy Hog
0 my sunday driver...
0 Cutting out at WOT
0 OEM Headlight Bucket?
0 Flat Tracker Pics
Last Post: Gary E
0 Tires & Shocks Needed: '90XLH 883
Last Post: Rollbar
0 New guy out of AZ.
Last Post: 1r0nH0g
0 V-Twin Solo Seat Plunger Kit
Last Post: fernf5
0 Identity crisis
Steph (55), yubman (50), Sporty1971 (50), Windesch (48), Mark_Bench (44), motherduce (42), sgtfry (39), Mrtechit101 (30)
Old 7th October 2013
ReddTigger's Avatar
Default Clutch squeal ? Bad throwout bearing ?
So my scheduled bikers for babies ride for yesterday had a hiccup..
first i lost my glasses, and couldn't find the back up, so i shoot into a convenience store and buy a pair of sunglasses (all they had, and there is no way anyone would call them "masculine") but I can ride, good..
jump back on the bike and clutch starts squeeling.. then i can't shift.. so i adjusted the clutch.. gets worse, i adjust the other way, better but crappy still..
i end up loosing a good portion of the ability to shift, as i ride it home, getting passed by the convoy of bikes (on the ride i was supposed to be on) going in the opposite direction..
i get home, pull off the derby cover, take out the ball and ramp assembly and the threaded rod goes limp.. rut roh.. that can't be good. the bearing is toast.
i cut it open and this is what i find..
and this
States I've Ridden in
71.3 hp 70.8 tq
norseXL's Avatar
norseXL norseXL is offline
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1994
Shit! Happened to me to, lost the clutch completely and of corse I was in down-town Oslo, wery funny,
Not!
Tore
"In the design of an internal-combustion engine, as in all creative work of this nature, the æsthetic side must not be overlooked.
In the first place, beauty of form and of proportions is in it self an admirable guide to mechanical correctness;
for mankind has come to regard as beautiful that which is mechanically correct, whether it be in nature, in architecture, or in enginering."
Sir Harry R. Ricardo
geoff's Avatar
geoff geoff is offline
Sportster/Buell Model: XL1200 Low
Sportster/Buell Model #2: XLH1200 - Dearly missed
geoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond repute
Just went through this myself - looks like the inner race is a weak spot
I was 3 miles from home on a less travelled concession road ... thank God for friendly farmers with a trailer.
My life isn't completely about my Sportster. However, my Sportster makes my life complete.
ReddTigger's Avatar
I ordered these bearings as listed in Grinds post.. we'll try them out
Originally Posted by ~Grind~ View Post
Throw-out bearings. OEM on the left and the 7200B angular contact bearing on the right.
Copied this post from another thread. Explains how to install the angular contact bearing. Thanks Dirty Don for the heads up on this bearing!
Originally Posted by Dirty Don View Post
I went out and looked at mine, all apart, and it looks like the primary cover might need to come off, maybe not. But the throw out bearing is in its own little housing, held in by a retaining ring and the assembly can be removed. Then you take the small retaining ring off the threaded shaft and press it out. The bearing itself can then be pressed out of its housing, press the new one in, by the outer race, making sure the widest side of the outer race on an angular contact bearing goes into the housing first, then replace the shaft and retaining ring, put the assembly back in with its retaining ring and it's done. You must be sure of the orientation on an angular contact bearing so your thrust is applied to the races properly. Then put your primary cover and the rest back together.
Ocgreenmachine's Avatar
Ocgreenmachine Ocgreenmachine is offline
Sportster/Buell Model: XB12Scg
Ocgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud ofOcgreenmachine has much to be proud of
Grind, any particular brand on the 7200B angular contact bearings? Also, size is 10x30, correct?
Sent from my iPhone using Tapatalk - now Free
2009 Buell XB12S w/Hammer Performance 1250 kit. Dean Adams RT-XB1 exhaust, Custom ECM.
Old 8th October 2013
rocketmangb's Avatar
Does the bearing "push" in or "pull" out when you cycle the clutch lever ?
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Was this for me?
wedge's Avatar
wedge wedge is offline
You should know that by now. It pulls out when you pull the lever. You are pulling the adjusting screw towards the derby cover and that is pulling the pressure plate away from the plates.
SO... On the pictures above, the bearing is installed in the holder so that the side facing you is the side shown on the right of the top set of pictures (the wider outer race is towards you). The adjuster screw is installed so that the threaded end points towards you, in the same direction as the wider side of the outer race. (The side with the numbers stamped in it).
Note, this means that the wide center race is facing away from you. (The side without the numbers)
ReddTigger's Avatar
On other words.
Fat end first
Why dont the fat outer race face out ?
http://www.skf.com/binary/12-97838/519961-.pdf
