Last Post: hhugger
0 Slip on muffler
Last Post: Tucsonmax1
0 1972 tank fitment
0 bike went for a slide
0 New England 2018
Last Post: The Crusher
0 90 in. Build
Last Post: Jheitt
0 Help me with gas cap...
0 Sportster or Street Bob
0 2016 48 Hesitating
Last Post: Screw Loose Dan
Last Post: dnaj11
Old 25th February 2008
CosmoTG's Avatar
CosmoTG CosmoTG is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: Kawasaki Vulcan 1500
CosmoTG is an unknown quantity at this point
Default Generator Mount Leak
Spent most of the day tracing down leaks and have found one I,m not sure how to fix. Seems that the mounting bolt holes in the generator are cracked. The bolts are tightening but I am afraid to torque them down for fear of more damage. Just had the generator rebuilt and I hate to shell out the bucks to replace it. Any body have any ideas?...Cosmo
I had that same problem with one of the bolt holes. I had an helicoil installed. Has worked fine for 2 or 3 years. Be sure to use one for fine thread.
If there is a problem with the structural integrity of the gen case i would consider wrapping it with a 4,1/2" hose clamp or two after the helicoils are installed.
Those bolts need only about 10 ft lbs; not very much at all; plus some blue locktite. Easy to over tighten and wreck.
There does need to be a gasket between the gen and the case. I made one from cork gasket material from the auto supply store.
Old 13th March 2008
CosmoTG's Avatar
Today I received a new Generator drive cover I ordered From Jireh (part# 53-253) for about 11$. This looks to fix my mount problem. Just gotta be careful not to over tighten...Cos
