Last Post: Monte03
Last Post: Fivecats
0 Getting old is a bitch!
0 Allegheny National Park III
0 Sportster S on the dyno
Last Post: Fivecats
0 1967 on FaceBook. Florida.
0 Tank flush
Last Post: RandallM
0 High beam not working
Last Post: joe s
Last Post: 84rzv500r
0 My new deer rifle
Last Post: Whitewalls
0 1995 Manual
Last Post: jeffro57
0 Massachusetts 2022
Old 18th November 2013
draboo's Avatar
draboo draboo is offline
Sportster/Buell Model: 883
draboo is on a distinguished roaddraboo is on a distinguished road
Originally Posted by toe View Post
You might also want to do this:
Enlarged oil drain from ~.070 to .09375 (the tiny hole below the triangular patterned hole) and add threaded inserts as oil standoffs
toe, could you explain those threaded inserts further? What is their function? Are they hard to install?
benton benton is offline
Sportster/Buell Model: Sportster Delux 883/1200
Sportster/Buell Year: 1988
benton has disabled reputation
Hylomar is great stuff for sticking the gaskets in place, but it got hard-to-find when pematec quit distributing it. It's still made by the original manufacturer.
toe's Avatar
toe toe is offline
Sportster/Buell Model: 883C
toe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond repute
Ok I'll try to explain.
Looking at the picture, you can see 3 holes that are in a roughly oval shape area in the corners of the middle rocker box cover. (2 per rocker box, only 1 is used per cylinder)
The one in the middle (triangle pattern) is where the umbrella valve goes.
With each downstroke, the air in the crankcase is forced thru the umbrella valve. The air has an oil mist in it.
The oil is supposed it settle out in this little chamber and drain back to the cylinder head thru the tiny oil (bottom of oval area).
Slightly enlarging the little hole lets the oil drain back easier.
Air that enters this oval(ish) chamber has to go somewhere. So it goes out the big hole on top, thru the breather bolts and out...........
The threaded insert just provides a lip around the hole. So any oil that drops out of suspension around the hole won't drain out the breather.
Just makes it a little bit harder for oil to go out the breather.
I just used the threaded inserts because I had couple left over from another project. You can use anything that does the same thing.
Ed
The Only Y2K dual-set 883C
So Cal
Old 18th December 2013
outside the box racing
Sportster/Buell Year: 99
Sportster/Buell Year #2: 2000
Other Motorcycle Year: 1991
i have never had any trouble with any rocker base gaskets, hd, james, cometic.
the rubber, on the other hand, can be troublesome. i got myself into a position where dealer was the only source at hand and they wanted double ($40) for a set. i choked but bought. am glad i did. they have redesigned them and they sit down and work much better.
TGB #8
sportytrash's Avatar
sportytrash sportytrash is offline
Sportster/Buell Year: 93
Other Motorcycle Model: '72 Bonnie
sportytrash is a splendid one to beholdsportytrash is a splendid one to beholdsportytrash is a splendid one to beholdsportytrash is a splendid one to beholdsportytrash is a splendid one to beholdsportytrash is a splendid one to beholdsportytrash is a splendid one to beholdsportytrash is a splendid one to beholdsportytrash is a splendid one to beholdsportytrash is a splendid one to beholdsportytrash is a splendid one to behold
I've had good luck with cometic's sealing. Cantankerous to install. Held in place with grease. Didn't know the MoCo had revised them at that time. Thanks for the tip, Toe (couldn't resist). Next time she's down...
"The mid-sixties XlCH is to motorcycling what a hooker's come on is to romance: crude, rude and unmistakable". Jim Miller Cycle Guide Dec. '84
Defender of the faith
Powerhouse drifter
Squirl1948 Squirl1948 is offline
Sportster/Buell Model: Sportster XL883
Sportster/Buell Model #2: 37'WLA
Squirl1948 is an unknown quantity at this point
Used aircraft gasket sdhesive,worked for me..
What do I know?
Old 27th December 2013
tmack-1's Avatar
tmack-1 tmack-1 is offline
Sportster/Buell Model: Sportster XLH1100
Sportster/Buell Year: 1986
Other Motorcycle Model: Speedway Green Horm
Other Motorcycle Year: 1972
tmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to all
James Gaskets.
Cost a little more but have good reviews.
Two years no leaks on my '86 using synthetic oil. Saw somewhere here that Syn oil leaks easier.
1986 XLH 1100 (fixer-upper) // Engineers design things, Technicians make them work. --- 30% of being mechanical is confidence/30% is knowing to go slow when needed/30% is looking repeatedly at what you have/10% is dumb luck .
ReddTigger's Avatar
Originally Posted by tmack-1 View Post
James Gaskets.
Original HD (redesign) been on the bike for close to 40,000 miles no leaks..
james gaskets leaked within 50 miles..the other in about 100..
I will insist on using the Cometic head/base gaskets, and HD rockerbox gaskets.
States I've Ridden in
71.3 hp 70.8 tq
Old 28th December 2013
denguy denguy is offline
Sportster/Buell Model: 1200
denguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond reputedenguy has a reputation beyond repute
x2 on checking for flatness. One of mine was warped and leaking. I worked it flat with a mill file and a steel straight edge. No more leaks.
SocalXLrider's Avatar
SocalXLrider SocalXLrider is offline
Other Motorcycle Model: Honda VF700F
Other Motorcycle Year: 1984
SocalXLrider is an unknown quantity at this point
I also had no idea the Motor Company had redesigned their gasket set. I replaced the front on mine around 11,000 mile ago with James gaskets and no leaks. My rear factory set has just started to leak with over 17,000+ miles on them. I agree with Toe earlier in this thread: clean up the mating surfaces. I have a piece of 1"X12"X12" surfaced marble that I put a sheet of 600 grit sandpaper on and clean up the pieces. I bought to sets of James gaskets when I did the front cylinder, so I am going to use those on the rear. I used James gaskets on my Buell M2 Cyclone and had over 40,000 miles on those with no leaks by the time I sold it.
