Last Post: groovemeisterus
Last Post: rwharris
Last Post: tvon
Last Post: KCinSB
0 Lightning strike
Last Post: Screw Loose Dan
Last Post: x1_guy
0 Manifold Leaks Gone !!!!
0 Masking stripes
Last Post: shooterj2003
0 no rear brake light
0 2016 48 Hesitating
0 Ei
Old 28th February 2008
74chopster's Avatar
74chopster 74chopster is offline
Sportster/Buell Model: sportster 74chopster xlch
74chopster has disabled reputation
Default timing oil pump
i timed my 1974xlch oil pump with my cam timing marks. is that right if so somEbody please let me know thanks............mark
74chopster's Avatar
ok yaw i called my local harley mechanic here in sc. rob steele who owns steele cycles. it was confirmed that when your cams are in there timing marks. and the vent hole in the oil pump should be visible in the notched part of the pump this is on a 1974xlch i looked in this forum couldnt find the answer so here it is. for whom ever needs to know this. i know if not in timed it will create heating issues
Jtrapass's Avatar
Jtrapass Jtrapass is offline
Sportster/Buell Model: XLH-1000
Other Motorcycle Model: Honda VTX 1800 Retro
Other Motorcycle Year: 2002
Jtrapass is on a distinguished roadJtrapass is on a distinguished roadJtrapass is on a distinguished roadJtrapass is on a distinguished roadJtrapass is on a distinguished road
I just lined my 75 up the other day. I'm a little weirded by the fact that there's stock intakes in there, but andrews pb+ exhaust, but it should be fine.... right?
When I was lining up the timing holes, I locked the engine at rear TDC (Vertical line in the timing hole for me), then I slipped on the worm gear the drives the oil pump (no good picture of this), and it had a mark pointing straight up. I lined this up with the oil pump's dot sitting right in the notch. It took a few tries to roll it into place but all was good. Then I lined up the pinion gear and everything looked like what you see below. Was everything the same for you?
- Joe
wrenching in my garage with a big stupid grin on my face.
thefrenchowl's Avatar
Sportster/Buell Model: KHK
Sportster/Buell Year: 1954
Sportster/Buell Year #2: 2008
Other Motorcycle Model: XLRTT
Yep,
That's the right procedure for timing the oil pump.
Patrick
Flat Head Forever
74chopster's Avatar
Ive timed mine in the past before but forgot its had been a while. and this same processes works for my andrews y series cams so it'll do the same for bp+ cams
Old 1st March 2008
Rush's Avatar
Rush Rush is offline
Sportster/Buell Year: 1973
Sportster/Buell Model #2: XB12X Ulysses
Other Motorcycle Model: Yami XS650 (custom)
Other Motorcycle Year: 81
Rush is a jewel in the roughRush is a jewel in the roughRush is a jewel in the roughRush is a jewel in the roughRush is a jewel in the roughRush is a jewel in the roughRush is a jewel in the roughRush is a jewel in the roughRush is a jewel in the roughRush is a jewel in the roughRush is a jewel in the rough
Looks right to me. When my boyfriend's motor came, I noticed the cam cover on this new "professionally" rebuilt engine wouldn't seat properly, so I removed it and lo and behold the cams were all out of whack. I re-installed the cams and now it seats just right.
Maybe it's my fault for not asking what sort of "professional" rebuilt the engine... a professional lettuce picker or what?
Now I need to go through this gem & see what else was professionally overlooked.
Old 1st March 2008
JonnyRtn's Avatar
JonnyRtn JonnyRtn is offline
Sportster/Buell Model: 1200 conversion
Sportster/Buell Model #2: FLH
Sportster/Buell Year #2: 1971
Other Motorcycle Model: FLHTC
JonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura aboutJonnyRtn has a spectacular aura about
WHOA... she fixed her BF's bike...... DAAAAMMMMNNNN... lucky guy...
Bolting foo foo on... is not building.... The dealer is not your friend, he is like the IRS, just wants your money.... Chopping up perfectly good motorcycles is fun, try it, you might like it...
Old 13th May 2008
rvwalke's Avatar
rvwalke rvwalke is offline
Other Motorcycle Model: yamaha yz250
rvwalke is on a distinguished roadrvwalke is on a distinguished roadrvwalke is on a distinguished road
ok so let me get this straight... i need to reinstall my oil pump... so with my cams all lined up with the timing marks all i have to do is install the pump with the breather hole lined up wiht that notch?
'73 XLH rigid, nothing has gone untouched
Old 13th May 2008
Jtrapass's Avatar
Yup. If you pull that normal gear off of the drive shaft, you'll see a pinion gear under it that drives the oil pump. The pinion gear has a mark on it, point that straight up in the air, while the oil pump's mark is in the notch. This will time your breathing. Then put that normal gear back on and all of the cams back in so the marks line up. Sounds simple, right? If you've got these off anyway, you might want to look into measuring the cam spacing and replacing the spacers if necessary. Mick's got a sticky on it.
Old 13th May 2008
rvwalke's Avatar
so lets say after its all together that hole is slightly off from that notch... what kind of problems might one run into running it this way?... just curious
