0 Stock 883 cold blooded
0 1977 Bright Blue
0 Not charging issue!
Last Post: Jowniofownio
0 99 1200s clutch drag
Last Post: NZstu
0 z bars
Last Post: jharback
0 Value of a Boattail?
0 1967 XLCH stroker project
Last Post: tvon
0 Viking bags??
Last Post: cotton1
0 2001 883 'customizing' log
Last Post: Jheitt
0 rpm jump pulling in clutch
Last Post: jammantoo
Last Post: lugster
Last Post: lugster
0 79 ironhead
Last Post: lugster
Last Post: cotton1
Last Post: halfmt1
0 V&H Shortshot question
0 Choppin' Cotton
0 79 ironhead
0 Head gaskets.
Old 20th January 2014
Eric Von Zipper's Avatar
Eric Von Zipper Eric Von Zipper is offline
Sportster/Buell Model: C for Chrome
Eric Von Zipper has much to be proud ofEric Von Zipper has much to be proud ofEric Von Zipper has much to be proud ofEric Von Zipper has much to be proud ofEric Von Zipper has much to be proud ofEric Von Zipper has much to be proud ofEric Von Zipper has much to be proud ofEric Von Zipper has much to be proud ofEric Von Zipper has much to be proud ofEric Von Zipper has much to be proud ofEric Von Zipper has much to be proud of
Default Belt guard lower removal
Ive seen a lot of RM EFI bikes with the either both or just the lower guard removed.
I am about to remove the lower plastic guard/guide.
Any cons doing this? The pro is its ugly and needs to go.
I will leave the nightster upper belt guard, stops the rain water from climbing up me leg
Headbarcode's Avatar
Headbarcode Headbarcode is offline
Headbarcode is a name known to allHeadbarcode is a name known to allHeadbarcode is a name known to allHeadbarcode is a name known to allHeadbarcode is a name known to allHeadbarcode is a name known to allHeadbarcode is a name known to allHeadbarcode is a name known to allHeadbarcode is a name known to allHeadbarcode is a name known to allHeadbarcode is a name known to all
If you ride alot of gravel roads, you risk punching a hole in a pricy belt when a stone eventually takes a ride over the wheel sprocket. It also has an adjustment gauge for the belt on it. I think it looks like shit myself and mine is long gone, but the only gravel my bike sees is the yard my shop is in and I take it slow anyway.
1996 XL 1200
rottenralph's Avatar
I think it helps keep small stones and gravel from getting in between the belt and pulley. I tool mine off in 93 and never looked back. never missed it.
joesporty's Avatar
joesporty joesporty is offline
Sportster/Buell Model: xl 883
Other Motorcycle Model: kz750
Other Motorcycle Year: 1976
joesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant futurejoesporty has a brilliant future
I've only seen two broken belts and both bikes didn't have a lower belt guard... One buddy had a little stick get in his while riding which broke the belt and the other guy i'm not really sure what happened but i blamed it on his recently removed lower guard...
SMOKEY BURNOUT MASTER OF THE WORLD!!!!!
08 XL883;HAMMER 1250,Heavy breather,Rinehart 2-1, Power Vision,Ebc floating rotor,XR1200 Nissin caliper,1200R Mastery cylinder,RK shocks,1in tank lift,wire tuck,crossroads fork brace,low rise drag bars int.wired,Goodridge Ss line,Chrome valve stem covers, and a few top secret parts..:smoke
spoon spoon is offline
Other Motorcycle Model: KLR 650
Other Motorcycle Year: 1987
spoon has much to be proud ofspoon has much to be proud ofspoon has much to be proud ofspoon has much to be proud ofspoon has much to be proud ofspoon has much to be proud ofspoon has much to be proud ofspoon has much to be proud ofspoon has much to be proud ofspoon has much to be proud ofspoon has much to be proud of
Well I still have the lower belt guard and picked up a chip seal stone which cut the belt. broken belt! Is the guard necessary? Don't know, but its not a guarantee that you won't get a rock.
Mosey Mosey is offline
Sportster/Buell Year: 1982
Other Motorcycle Model: FX
No!! Don't do it! You will crash and burn within ten miles. Most accidents are caused by the lack of a belt guard or removing the second throttle cable. Do you remove the tags that say, "Do not remove" from the mattress in yer bed? Yer livin' waaaay out on the edge...
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Model #2: Xl 883n
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 1977
Originally Posted by Mosey View Post
No!! Don't do it! You will crash and burn within ten miles. removing the second throttle cable. Do you remove the tags that say, "Do not remove" from the mattress in yer bed? Yer livin' waaaay out on the edge...
Damn, I'm doomed I removed 2 of these!
jonnybegood jonnybegood is offline
Sportster/Buell Model: sportster xl 883 low
jonnybegood is on a distinguished roadjonnybegood is on a distinguished road
If you don't like it get rid of it. Your choice. I've removed mine a couple of years ago no probs. touch wood
rubine rubine is offline
Sportster/Buell Year: Bits
Other Motorcycle Model: '00
Im only gonna be running 1 cable in an internal throttle. Calculated risk I can control. I cant control the lil ol lady with bad hearing and eyesight that may pull out in fromt of me!
Only dirt or rocks mine sees is a 10 foot patch between the road and my concrete driveway. Most of the time I just cut across the lawn. So no rocks unless I pick one up on the road.
Hey Mosey, I live dangerously, dont use rubbers either! Have not had a kid yet (cept the one my ex wanted)
That ugly sucker is sooo gone
