Last Post: mor
Last Post: BILLETPROOF
Last Post: Aden
0 THE Trainspotting Thread
0 48 Handling
Last Post: 201648Rider
0 Mid's or rear sets
Last Post: gusm2
0 Blow thru setup
Last Post: Sideshift92
0 -75 ironhead, My first HD
Last Post: blindfredy
0 91 oil in cam cover
0 Safe to run 2 master links?
Last Post: Reverend G
Old 20th March 2014
KICKSTAND85 KICKSTAND85 is offline
KICKSTAND85 is an unknown quantity at this point
Default stage II screamin eagle kit
I have been looking around every where I know to find the Screamin Eagle Stage II kit. Does anyone know if i can even put it on my 2010 Iron 883? Thanks for the help!
Old 20th March 2014
tyler.woodard04's Avatar
tyler.woodard04 tyler.woodard04 is offline
Sportster/Buell Model: 883L-1250
tyler.woodard04 is a glorious beacon of lighttyler.woodard04 is a glorious beacon of lighttyler.woodard04 is a glorious beacon of lighttyler.woodard04 is a glorious beacon of lighttyler.woodard04 is a glorious beacon of lighttyler.woodard04 is a glorious beacon of lighttyler.woodard04 is a glorious beacon of lighttyler.woodard04 is a glorious beacon of lighttyler.woodard04 is a glorious beacon of lighttyler.woodard04 is a glorious beacon of lighttyler.woodard04 is a glorious beacon of light
Don't waste your money. Got to hammer performance and you will be much much happier. They are a vender here and have their our section as well
Tyler
Hammered in a 103.7HP animal
[SIGPIC][/SIGPIC]
Old 28th March 2014
lugster's Avatar
lugster lugster is offline
Sportster/Buell Model: xl883r
lugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond reputelugster has a reputation beyond repute
Here you go http://www.kutterharleyonline.com/ha...n-kit-29836-100cc-stage-ii-conversion-kit-29836-10 Heads do not come with this kit
Old 28th March 2014
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
It says race application only. Time to make it a full on drag bike.
Old 28th March 2014
lugster's Avatar
He could not have been looking to hard. I didn't know screaming chicken made a stage 2 kit so I googled it. I'm with Tyler on going to Hammer, but that's just my opinion.
Old 28th March 2014
as others have said you would make much more power with an NRHS 1250 kit, our stage 2 headwork using your heads and a set of NRHS Cat 3 cams. results such as this:
100 hp and 85 ft lbs of torque. This is my wifes' daily driver 2007, it is not a dyno queen, and the dyno was done before it was even fully broken in.
Old 28th March 2014
lugster's Avatar
Dan I think you could of said more about your company if you had left out the remark about dyno queen.
Old 28th March 2014
It was a very appropriate comment. I do not believe in building engines just to look good on the dyno but they suck to actually ride. if somebody finds the remark offensive then perhaps they need to ask themselves why.
Old 28th March 2014
lugster's Avatar
I would think that R&D would be the reason for Hammer to Have the mule. I see you reference your wife's bike a lot. Why?
Old 28th March 2014
I reference her bike as it is a very simple build we have done using 883 heads and if somebody wants to come to my shop and ride it they can. As I said it is not a dyno queen. it is a real world daily driver. I had it at the XL shootout last year and it and beat the crap out of it with zero issues.
Who said anything about hammers bike? I didn't so not sure why you felt the need to? Seems like it is you who is trying to stir things up. So let me ask you... WHY???
