0 Hello from southern Ontario
Last Post: jharback
3 Wtb, Wts, Wtt, Wtg (Rubber Mounts)
Last Post: bobber58
6 1997 Sportster S putting +4 front shocks??
Last Post: 1mellom8
0 Riding in the rain
0 Just sending out some good vibes~
Last Post: 1mellom8
0 2005 Rear Brake Rotor
0 Mick Abandoning PhotoBucket
0 Nashville Tennessee
Last Post: William63
0 .551 Cams in an EFI 1200
Last Post: Huginn
0 Mechanical regulator
Last Post: sportysrock
0 Breaking in a 17-year-old demo
Last Post: motorend
0 Wet sumping?
Last Post: WI_duker
0 Oil Temp Dip Stick
0 2020 Sportsters
0 '04+ Starting Issues, Do You Have Them? - Poll
Last Post: Bikeaholic
0 Do You Have a Deer Whistle or Shu-Roo on your Bike?
0 June 8th, 2019: Ironhead Rider's Gathering, PA/NJ (Spring 2019 G.B.B)
Last Post: 72 Ironhead XLH
0 Magneto upgrade questions
Last Post: Scott
7 I met a living legend.
0 what brake master cylinder can I use?
Last Post: Sadsack
0 Missing this bolt at tappet base, help identify
0 I know I'm gonna catch flack for this...
0 Carburetor 101 Float valve question
5 Are you married or single???
Last Post: jcn59
0 Lifted 48
0 Sad day ... Time to learn some more...
Last Post: TX Dreamer
Old 24th November 2005
Gone Gone is offline
Banned
Gone is an unknown quantity at this point
Default How-To: Shock install
Just got Progressive 412 - 11" shocks for my wife's 883 Low.
What is the proper procedure to install them. I don't have the HD tech manual. It looks simple enough......But, I've damaged enough stuff to know better.
Rick
gronk62's Avatar
gronk62 gronk62 is offline
mostly harmless.. (sssm)
gronk62 has disabled reputation
I find the easiest way is if you have a bike lift/stand of some kind.
I use this combined with a small jack under the cast peice that the rear brake master cylinder bolts to..
Make sure you loosen the nut first on the lower shock bolt. If you try to undo the bolt before you loosen the nut you could strip the stoopid torx drive thingo which is a size "50".
The top bolt is also really tight so go carefully.
Once you have the old shocks removed just adjust the jack height to suit the length of the new shocks so they line up with the holes.
Reassemble using whatever combination of spacers and washers works for you.
I use this combination for the lower mount but there are several different ways that all work well.
bplinson's Avatar
bplinson bplinson is offline
The XL Forum Host
Sportster/Buell Model: 883>1250 Stage 2
Other Motorcycle Model: Road Glide
Other Motorcycle Year: 2011
bplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond repute
Also remember that if you take off both shocks at the same time the rear wheel will fall a few inches. If possible just do one side at a time.
Don't forget to check the tightness of the belt when you are done.
AMA #961454
gronk62's Avatar
I use the jack to keep the rear wheel just touching the ground so I can take both off together.
It makes it easier to fit shocks that differ in length from standard.
I removed 13.25" shocks and lowered the jack to shorten the distance between mounts to 12" so my new shocks just fit straight on with no wrestling
Old 25th November 2005
Banned
Gronk,
You say, "Make sure you loosen the nut first on the lower shock bolt. If you try to undo the bolt before you loosen the nut you could strip the stoopid torx drive thingo which is a size "50". The top bolt is also really tight so go carefully."
OK, I see the bottom mount has the Torx bolt going into the nut. Is the top mount threaded directly into the chrome fender support??
Oh yeah, how about the proper tourque setting?
Rick
GOTWA's Avatar
GOTWA GOTWA is offline
GOTWA will become famous soon enoughGOTWA will become famous soon enoughGOTWA will become famous soon enoughGOTWA will become famous soon enoughGOTWA will become famous soon enoughGOTWA will become famous soon enoughGOTWA will become famous soon enough
Rick
Yes it is.
Still looking for the torque spec.
I'll tell ya this, I didn't torque mine. Just blue lock-tite.
GOTWA's Avatar
Okay, found it, from the MoCo service manual (if you don't have one, get one )
45-50 ft lbs for top and bottom.
gronk62's Avatar
The fender support is a cast section with a chrome cover and yes the bolt just screws straight in.
Torque? I never bother with torque settings on bolts like that. Just a bit of blue loctite and do it good and firm. NOT stupid tight like they come from the factory.
merc merc is offline
Sportster/Buell Model: Custom
Other Motorcycle Model: Suzuki GN400
Other Motorcycle Year: 1980
merc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond repute
good thread guys.
I watch for all these how to's and document them in case.
denise1955's Avatar
denise1955 denise1955 is offline
Sportster/Buell Model: 883C
denise1955 is on a distinguished roaddenise1955 is on a distinguished road
Thanks for the thread guys - I'm printing it off. This is my next modification.
Denise
Denise
'05 883C
