0 Poll: Hwy Pegs: fwd mount or crash bar mount?
Last Post: oupa
0 Best Tuner options?
Last Post: Dilera
0 How tricky is it to replace dipstick trim from oil tank?
0 su carb question
Last Post: Serious Blac
6 SPORTY BOBBER PICTURES
0 Happy Birthday Mrs. Folkie.
0 Buell special
0 how do eat an elephant,,
Last Post: cazz1000
0 Clutch lever pull effort
Last Post: Centennial Sportster
0 Psychedelic '70s SPortster Chopper Pictures
Last Post: Bryan83taco
0 What engine oil do you use?
Last Post: TUCCI
0 Too HOT to ride?
Last Post: PetesPonies
Last Post: burely
0 Another clutch Question
Last Post: wrkdWS6
0 CV Carb - Transfer Ports
Last Post: XL Ed
0 Cleaning clutch
Last Post: tussuck
0 my recent ebay purchase
2 My 1275 Hammer Conversion..
Last Post: wrkdWS6
0 Iron-shed
Last Post: smokey 2
0 Frame bracket
Old 28th April 2014
sportsterdoc's Avatar
Default Bank Angle Sensor bypass
H-D added the BAS to kill the engine when the bike is laid on its side. That function does not always work (personal experience on a new 2003 XLH883) and sensor failure will inhibit the engine from starting. The BAS on rigid models is under the triangular plate, to the rear of the battery.
To bypass a failed BAS (or to simplify wiring), the BAS can be easily bypassed. My experience is with rigid mount EVOs, but the principle is the same for rubber mounts. H-D uses a fail-safe sensor principle: A sensor must close to ground. For example, the neutral safety switch completes a circuit to ground, when the trans is in neutral. Same with the clutch switch, when the lever is pulled. This is opposite brake light switch operation, which switches 12 VDC from the accessory switch (orange/white) to the brake light (red/yellow) switch leg.
On my 1200 Sport (2002 1200S domestic and international main harness page 5-29), the BAS has three wires and receives power from the gray wire (from the ignition fuse) which also powers the “engine stop/run switch”. If removing the sensor, that 12 VDC wire will need to be capped. Connecting the light green/gray wire (from the module) to ground, via the black wire, will provide run mode.
Old 10th May 2014
driver354 driver354 is offline
Sportster/Buell Model: XL1200s
driver354 is an unknown quantity at this point
Great info, any chance of posting a pic for those without the service manual?
Old 10th May 2014
Not set up to post photos, but the wire colors are listed
Old 29th March 2015
Bramble_skull's Avatar
Bramble_skull Bramble_skull is offline
Sportster/Buell Model: XLH 883 Hugger - 1200
Other Motorcycle Model: Softail Standard
Bramble_skull has disabled reputation
I'm wondering if that's what is wrong with my 2002 Hugger. No start no way.... was waiting for delivery on new plugs & HT leads... which are a bit tired... but time to go investigate BAS methinks!
Ride hard or stay home.
Old 29th March 2015
I'm seeing three wires on my Hugger 883 2002 wiring diagram:
Black,
Green,
Grey.
I think you are saying cap the grey, then join / connect the green to black... is that the deal?
Old 29th March 2015
This is what I have
This is what I think you are saying to bypass the Bank Angle Sensor?:
Old 29th March 2015
Black,
Green,
Grey.
Yes
Old 29th March 2015
This is what I have
Yes
Old 29th March 2015
Thank you
Old 31st March 2015
Sorted the BAS, removed it and linked as suggested. Treated her to new plugs & HT leads... nice fat spark... figured its sorted... But no.
No fuel!!! tap is dry, tank has fuel.... what have I done wrong?
