0 photo size
Last Post: stikflote
0 V&H slip on twin slash
Last Post: Jack250
0 TC88a DIY Power adapter ?
0 Fuel tank urns
2 Your daily tunes...
0 61xlh started with starter fluid
Last Post: Larry May
0 Still having trouble starting the 61xlh
0 Krome Werks HP Plus slipons - Replacements ?
0 2011 Harley 883 Iron 1250 Hammer
0 Figure Machine external breather
0 Black Bike Bible
0 Frankenbrakes
0 su carb question
Last Post: nychopper
0 Hello from Northern Alberta
0 Who Runs Turn Signals?
Last Post: Gpa
0 Stock Shocks/Oil Pump
Last Post: whetrick1
0 Too HOT to ride?
Last Post: Skeezix
2 My 1275 Hammer Conversion..
0 Trans corner fix
0 cam lobes
0 Misc. Parts/cleaning house
0 HSR42 Dealer Jet Kit
0 Daytona Twintec TC88/TC88A USB Interface
0 New Buell Rider From Southern MN
Last Post: Veeflys
hubbinator (71), sport53 (67), kship (55), jrmkel (41), IR88n3 (36), waltweezy45 (33), lumberjack (30)
banjo bolt, brake hose, front brake, master cylinder, over tightened
Old 30th May 2014
cervantzt cervantzt is offline
Sportster/Buell Model: Sportster XL883
cervantzt is an unknown quantity at this point
Unhappy Front Brake Banjo Bolt Locktite?
I'm trying to loosen the banjo bolt on my 2000 Sportster 883 to get a better angle for the hose off of the master cylinder after switching back to stock handlebars and the banjo bolt will not budge. I did not feel that this problem was exclusive to my bike, so I didn't prefix.
I've tried all of my wrenches, mallets and drivers/drills that could fit it. The head is not stripped and I almost think it has been severely over tightened or maybe even had loctite put in the threads. I just got the bike, and i'm new to HD bikes, but not to motorcycles or working on them. I have no clue how to loosen that sucker up. Is penetration oil able to get past the crush washers?
I need any tips, tricks or suggestions.
Old 30th May 2014
sportsterdoc's Avatar
Since you mentioned a mallet, you have probbly have already done what I would suggest:
Place a 12 point 7/16 box wrench over the bolt head, keep your thumb over the wrench/bolt head, then tap on the other end of the wrench (CCW) with a rubber mallet.
Old 30th May 2014
ReddTigger's Avatar
IMPACT DRIVER and proper fitting socket..
two good whacks and you should be turning it with your pinkies.
States I've Ridden in
71.3 hp 70.8 tq
