0 ironhead oil pump pressure
Last Post: tiderider
0 Pinion gear position
Last Post: NP72Iron
0 New guy
0 Sissy bar and rack for 883
Last Post: RandallM
0 So who's UK based?
Last Post: Dusz
0 Front Master Cylinder Gaskets & DOT 5
0 Upgrade carb kit
Last Post: ericfreeman
0 Mid or forward controls.
Last Post: lostNdallas
0 He... He... He...
Last Post: ZTatZAU
0 oil cooler
Last Post: MDT
0 Burly Stilletto 13" shocks or ?
0 Chinese sportster
7 Hello from Baltimore, MD
0 What do you want for Christmas? - 2022.
Last Post: Keep it running
0 Arthritis
0 93 sportster switching to laced wheels
0 Changed The Fork Oil
0 Gift Cards - The Perfect Gift! They'll Thank You Each Time They Ride!
0 springer forks rubbermount 04+
Last Post: Butch 73
Greg81XLH (57), saylor01 (56), Alicia (54), latnyte (53), antonini (45)
Old 1st December 2005
dodgenbullets's Avatar
dodgenbullets dodgenbullets is offline
Sportster/Buell Year: 06
Other Motorcycle Model: yamaha wr426 offroad
dodgenbullets has disabled reputation
Default running a Twin tech?whats yours set at
I just installed my TC-88 on my 06 1200r.I understand you have to experiment a bit to find what works best on each application.those of you that have had them a while where did you find your best all around setting?I got some good reults with my stage 1 after reading posts here and asking questions.got a big sucker a/c and cycle shack slip ons.45 pilot 180 main,two shims .40 , and drilled my slide vacume hole slightly bigger,75 HP and 75 torque,that was a good bang for $200 bucks.when i look at my dyno runs the HP and torque were still headed up when the limiter kicked in.from what i understand a stock stage 1 doesnt make much more power beyond that so i got the rev limit at 6300 rpm, dont plan on spending much time up there but it will be nice not to bump the limiter when shifting at 6000 rpm.right now i put it at 2 initial and 3 on the total advance.i did notice the bike started instantly and ran smoother.i couldnt ride it tho i got a kidney stone workin its way out.any advice or personal expeirence?on the TC-88 that is, not the stone.
Johnny G's Avatar
Johnny G Johnny G is offline
Riding with Angels
Sportster/Buell Model: Darkside
Other Motorcycle Model: Harley Davidson FLHTPI
Johnny G will become famous soon enoughJohnny G will become famous soon enoughJohnny G will become famous soon enoughJohnny G will become famous soon enoughJohnny G will become famous soon enoughJohnny G will become famous soon enough
My 2005 1200 C is on 1 and 4 I was getting a small amount of detonation on 2 when I let the clutch out. I runs awsome on 1 and 4 with no pinging 6300 rev limit. I run 91 octane stage 1 S&S air filter, Vance & Hines pipes, 48 pilot, 85 main , 82 RWHP
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
Smile Tc88a
Mine is set at 5-7 and 6800 rpm. Instant start. No dyno, but my buddy with a 111" S&S can't catch me 0-100(when running KW HP-Plus exhaust). Just put on LSR 2-1, but haven't had it on the road yet.
04/07 1275 BFH heads Darkhorse XB crank .600 cams S&S 1.725 rockers S&S precision lifters BDL+15% clutch TC88A HSR-45 S&S 3" ac LSR 2-1
Turbota's Avatar
Turbota Turbota is offline
3 - 3 and 6,800 with 91 octane and 10.5 to 1 compression
No pinging that I can hear ... Maybe I could try 3 - 4 next?
seajay ... are you using stock compression pistons?
seajay's Avatar
Default Tc88a
Turbota. Yes,but I had NRHS take .015 off when they did the heads(10.17:1 CR per NRHS fact sheet). Always run 93 octane.
Turbota's Avatar
okie dokie ... Well, 91 octane is the highest we get in Arizona unless you buy race gas.
My problem is; My hearing is not that good and I have a bad high freq. hearing loss from years of flying in the military, plus, the pipes are loud ... so, if my bike is pinging just lightly, maybe I'm not hearing it ????
I guess the best thing anyone could do is put the bike on the dyno when trying various settings.
I still may change mine from 3-3 to 3-4 and see how it runs. I can tell you this; The bike pulls harder right to the rev limiter than with the SE module.
seajay's Avatar
Default Tc88a
I took a small screwdriver with me to a desolate road, trying different settings. Had, what I felt was the best settings, in less then a hour.
bshadbolt's Avatar
bshadbolt bshadbolt is offline
Other Motorcycle Model: Suzuki GSX750ESG
Other Motorcycle Year: 1989
bshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura aboutbshadbolt has a spectacular aura about
I run mine at 1-7. It seemed to ping at 2 or higher but seems to love an agressive advance curve. Haven't got anywhere in Singapore that I can do roll-ons so this may not be ideal, but the bike goes beautifully.
Actually, I am using a custom curve which I programmed which is close to 1-7 but smoothed out a bit.
Cheers,
Brett
Old 2nd December 2005
Scout99's Avatar
Scout99 Scout99 is offline
Scout99 is an unknown quantity at this point
Custom map based upon a 2-7 setting...smoothed out the curve in Excel using some simple math. I can't hear any pinging and it feels very responsive. I notice that when you upload a custom map into the module and then downlaod it, there are diferent values in the table...very minor, but still differences. Still riding around with a laptop and have the cable attached incase I want to screw around with it more.
bshadbolt's Avatar
If you have loaded a custom curve don't forget to set the initial advance switch to 5, otherwise it will adjust your custom profile up or down depending on where you have it set.
Cheers,
Brett
