Last Post: Fivecats
0 Getting old is a bitch!
0 Allegheny National Park III
0 Sportster S on the dyno
Last Post: Fivecats
0 1967 on FaceBook. Florida.
0 Tank flush
Last Post: RandallM
0 High beam not working
Last Post: joe s
Last Post: 84rzv500r
0 My new deer rifle
Last Post: Whitewalls
0 1995 Manual
Last Post: jeffro57
0 Massachusetts 2022
Old 19th August 2014
geoff's Avatar
geoff geoff is offline
Sportster/Buell Model: 1982 XLH 1000
Sportster/Buell Year: 1982
Sportster/Buell Model #2: XLH1200 - Dearly missed
Sportster/Buell Year #2: 1994
Other Motorcycle Model: 2008 XLH Low Anniversary
Other Motorcycle Year: 2008
geoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond repute
No worries ... now get to fixin'
My life isn't completely about my Sportster. However, my Sportster makes my life complete.
sportysrock's Avatar
Sportster/Buell Year: '96
Sportster/Buell Year #2: '72
Watch out on a pipe thread, because they're a taper and over tightening may crack your carb. Try a little PTFE pipe dope, or a bit of teflon tape.
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
Got any marine stores in the area, they sell them. Thread is 1/8 inch pipe thread
straight, 90 elbow, 90 street elbow
russzx6's Avatar
russzx6 russzx6 is offline
Sportster/Buell Model: 1000cc Ironhead Sportster
Other Motorcycle Model: 96 KDX200 Dirt Bike
russzx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to all
Grease nipples are another option to try and work out your thread size and pitch
24 beers in a carton. ...24 hours in a day . .. coincidence??
DR DICK's Avatar
DR DICK DR DICK is offline
simplified pipe thread info for the garage guy.
pipe threads come either straight (nps) or tapered (npt).
both are based on the pipe outside diameter as follows:
1/8 pipe = .405 pipe dia.
1/4 pipe = .540 dia.
3/8 pipe = .675 dia.
the above sizes are the major dia of the male straight thread (as the pipe od is the major).
and
major dia. of tapered male thread at its big end (if fitting is made to the americian standard).
the tapered thread has diameter reduced on a taper of .0625 per inch of thread length.
almost all hardware store fittings will be tapered thread.
little known fact:
all iron heads pipe threads used in cases, rocker boxes, and oil pumps are straight female thread, fitted with tapered thread male fittings.
this is a common automotive practice when dealing with low pressure apps.
D.D._____________________________-o&o____________________________
scottfisher's Avatar
scottfisher scottfisher is offline
Sportster/Buell Model: FLCH
Sportster/Buell Year: 61
Sportster/Buell Year #2: 60
scottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to beholdscottfisher is a splendid one to behold
Canadian tire has their own name brand tap/die set on sale this week. It is $39.99 regular $149.99. It is not a professional quality set but it is good enough for the garage mechanic and being the mastercraft name it has a lifetime warranty. I use it for cleaning threads, re-tapping stripped threads for the next size and determining what size nut/bolt I need to get for lost and broken bolts etc. I've had no problems with mine and I use it fairly regularly.
I wouldn't normally endorse this because it is manufactured overseas but for a builder with a budget it worth it.
s
Scott
'61 'CH
'60 'CH
