0 New in NM
0 FNG from OKC
0 Tried to buy a new helmet
Last Post: kap
Last Post: _Outlaw
0 Screw Loose's Repairs
Last Post: Screw Loose Dan
0 Tank swap
Last Post: Grymy
0 Lowboy frame conversion
Last Post: spacecoast
0 Primary Oil INSANITY!
0 What jets do you use?
Last Post: David L.
Last Post: David L.
Old 22nd March 2008
judas's Avatar
judas judas is offline
Sportster/Buell Model: xl883r
judas is an unknown quantity at this point
Default speedo stopped working
i have an 06' 883r and my speedo stopped working along with the neutral indicator. i removed the speedo to mount a fairing and put it back on today to find it not working. whats wierd is all the warning lights illuminate and the speedo backlights are on but the needle doesn't move and the neutral indicator doesnt work either. when i turn the key the flashers blink twice, is this a fault code, and is their a way to reset it? thanks
Well, if I knew how to make a cool sig it would go here.
[url]http://xlforum.net/photopost/showgallery.php/cat/500/ppuser/5803[/url]
Old 22nd March 2008
xena's Avatar
xena xena is offline
Assistant Administrator
These two threads may help you troubleshoot the issue.
http://xlforum.net/forums/s...ad.php?t=18260
http://xlforum.net/forums/s...ad.php?t=29021
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams
Python 3 Slip ons
TC88A running Xena's Black Panther Map
My 1212 Conversion Thread
XL Forum Members Map
Old 22nd March 2008
judas's Avatar
i cant seem to get diag mode to work. did they change the way to do it for 06'?
Old 22nd March 2008
misterT's Avatar
misterT misterT is offline
Sportster/Buell Year #2: 1976
Try reseating the electrical connectors, take them apart make sure none of the pins slide back then plug them back together. Look for wires that may have broken, usually this happens by the connector where the pins are crimped onto the wires.
