0 oil pump
Last Post: factory rat
0 Please help with muffler identification
Last Post: RKN
0 teflon buttons or circlips?
0 1985 Ironhead, help with dynatek 2000 install
Last Post: atengnr
0 Dreaded carb again
Last Post: VXDspud
0 Where To Get Free Air
0 I bought a Sportster last month, but I don't know what to do now, when it leaked the
0 Intake Seals
0 Piston melted
0 Bob The Chicken
10 Introduction
0 82 XLH in Arkaksas
0 Venhill cable
Last Post: 93trident
0 Help & advice needed
Last Post: Andy Hog
0 My 99 883 c
Last Post: 99-883-c
0 Electrical problems.
Last Post: Andy Hog
0 New to HD
Last Post: Tyler45
0 Cam followers have locked up internally. No movement at all. Why?
0 LED Headlight?
0 Anyone know who can shorten fork tubes?
Last Post: Whitewalls
PlanB, Cuco6924 (75), 1200sporty (64), iron68 (50), LifesHarlequin (37), mattosm (36)
Old 22nd March 2008
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Default Idle Mixture Needle Mod
I fitted the CCP (now John's Cycle Parts) EZ-Just idle mixture needle:
(click)
You can get them from J&P Cycles too.
This replacement needle makes it so much easier to adjust the idle mixture! I made a little modification to mine. I added a spigot to the face of the knob, to make it easier to turn. Well, to count the turns really. I screwed the needle in all the way (gently seating it), and marked the side nearest the air cleaner (right of bike). I then took the needle out again and drilled and tapped (10 BA) for the spigot I'd made:
Folkie
South East England Riders
Old 22nd March 2008
Swankster's Avatar
Swankster Swankster is offline
Master Bike Builder
Sportster/Buell Model: Nill
Swankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the roughSwankster is a jewel in the rough
Cool! Folkie, kind of like one of them steering wheels in a cage for a handicap person.
Swankster
"Stop Global Whining"
"Life, Liberty and the Pursuit of Anyone Who Threatens It"
"A Dead Enemy Is A Peaceful Enemy - Blessed Be The Peacemakers"
Still BIKELESS & hating Life!
Old 22nd March 2008
grindbastard's Avatar
grindbastard grindbastard is offline
Sportster/Buell Model #2: xl1200c
Sportster/Buell Year #2: 2005
grindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the rough
Well that's just about the freakin coolest thing I've seen so far this (shitty) day.
gb
"...they mostly come at night......mostly."
2005 XL1200R - Arlen Ness Big Sucker AC, Cycle-Shack slip-ons, #185 Main/#45 Pilot, DynaTek Dyna 2000 Ignition, Forward Controls, 12" air shocks
2005 XL1200C - Stock as F*#k.
Old 22nd March 2008
toe's Avatar
toe toe is offline
Sportster/Buell Model: 883C
toe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond reputetoe has a reputation beyond repute
I just marked the knob so I'd know where it was........
Also after you're all done getting your mixture set, put a dab of RTV on the screw (partly on carb body, partly on mixture screw) so it doesn't vibrate out.
Ed
The Only Y2K dual-set 883C
So Cal
Old 27th April 2008
Folkie's Avatar
Brass Nut
Not really necessary if you've only gone 3 - 3½ turns out. If you're at more than that, change to the next biggest slow jet.
Old 28th May 2008
tchuck's Avatar
tchuck tchuck is offline
Sportster/Buell Model: 883R
Other Motorcycle Model: FLE
Other Motorcycle Year: 1955
tchuck is an unknown quantity at this point
Default Homemade
I made my own.
This:
Plus this:
Equals this:
I bought some 3/16" brass tubing and a knurled nut from Ace hardware. If you accidently get solder in the threads, clean them up with a M6X.8 die.
Total parts cost; $1.98
EZ-just cost; $29.99
Savings; $28.01 = 7.39 gallons of gas = 370 miles of riding.
Old 28th May 2008
Folkie's Avatar
Brass Nut
That's a nice job! Now all you need is to do my mod to that knurled nut.
Old 5th July 2008
Gone Gone is offline
Gone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud of
Aha..... I knew I came to the right place. Thanks for all the suggestions. I chose to order the EZjust from Johns. Thanks for suggestion. I liked all the neat mods too.
Old 5th July 2008
steveb71's Avatar
steveb71 steveb71 is offline
Sportster/Buell Model: XLH883/1200 taxes paid
steveb71 is on a distinguished roadsteveb71 is on a distinguished roadsteveb71 is on a distinguished roadsteveb71 is on a distinguished road
Cool mods Folkie and Tchuck. I took the easy way out and used a marker on my EZ just screw but yours sure looks cooler.
Democracy is Two Wolves and a Lamb Voting on What to have for Lunch. Liberty is a Well-Armed Lamb Contesting the Vote--Benjamin Franklin
Old 5th July 2008
Hot Rod Sporty's Avatar
Hot Rod Sporty Hot Rod Sporty is offline
Hot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud ofHot Rod Sporty has much to be proud of
I just drilled a hole through mine from side to side and superglued a screw in... sorry, but I don't have pics....
________________________________________
PROUD MEMBER OF THE 'IGNORED BY '79' CLUB :banana __________________________________
RIP James "Mr. Jimi" Melton - 1947-2008
Godspeed brother.
"Dream as if you'll live forever. Live as if you'll die today." --James Dean
"A narcissist is someone better looking than you are." --Gore Vidal
"I just love the 'mechanicalness' of it"
--Indian Larry Desmedt
