0 First start question
5 Rethinking 1250 Build
1 Buy your New iPhone 13/ 13 Mini/ 13 Pro/ 13 Pro Max in Bulk and good price
Last Post: sinikbab22
0 Exhaust question
0 Timing, static or strobe?
0 Starter Relay?
Last Post: xena
Last Post: Andy56
0 33.4mm fork bushings
Last Post: 4cam
0 help with stuck engine
0 1988 1200. Unable to get oil pressure. New pump, new filter, new pipes, new oil.
Old 5th January 2015
jc1753hughes's Avatar
jc1753hughes jc1753hughes is offline
Sportster/Buell Model: xlh ironhead
jc1753hughes is just really nicejc1753hughes is just really nicejc1753hughes is just really nicejc1753hughes is just really nicejc1753hughes is just really nicejc1753hughes is just really nicejc1753hughes is just really nicejc1753hughes is just really nicejc1753hughes is just really nicejc1753hughes is just really nicejc1753hughes is just really nice
Heres a pic of my 77 cam cover if needed for reference.
-Jay
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
on a `77 that should be the foot brake and if so ,a 72 cover should be able to retrofit
because the shift lever for a 72 and a brake lever use the same hole.
randy3934's Avatar
If I'm not mistaken the 77 uses a different pinion bushing in the cam case.
can someone confirm the pinion bushing part number because it is missing from the parts manual for 57-78. shows up as 25593-74 in the 78-85 manual
Old 6th January 2015
Sportster/Buell Year #2: '03
your right.item's 31 thru 35 are missing. we do know '77 started different pinion shaft,pinion gear,and case bearing.
what I would do is plumb the vent to a parker flow safety valve with a cracking pressure of 1psi. you could just use hoses but it would look redneck so I would use stainless tubing. the valve could be hidden just about anywhere but make sure the vapor goes to a safe location. if you need a pic, I will post a link.
brucs, sounds fine but if only the bushing size is different one could fit an earlier pinion shaft bushing in a 77 cover and visa versa. Thinking the physical size and casting of the cover remained the same
DR DICK's Avatar
DR DICK DR DICK is offline
57-62
63-67
68-70
71-76
77-78
79-80
i dont have a pic for 81-e84
L84-85
52-78 have only one breather port at 6:00
79-85 have two. one at 6:00 and one at 10:00
52-76 use .625 pinion bushing bore.
77-85 use .562 pinion bushing bore.
D.D._____________________________-o&o____________________________
Fridge's Avatar
Fridge Fridge is offline
Sportster/Buell Model: XLCH/H
Sportster/Buell Year: 1973
Other Motorcycle Model: Road King Classic FLHRCI
Other Motorcycle Year: 2007
Fridge has disabled reputation
In my trusty 54 thru 78 FPM, it shows:
25593-57 BUSHING,gear shaft................ 57 to 76-XL,XLH,XLCH
25593-74 BUSHING,gear shaft................77 to 78-XLH,XLCH
DR DICK's Avatar
