0 Easy start cam choice
Last Post: cazz1000
0 05 1200R cylinder oil leak and clacking
0 I bought a Sportster last month, but I don't know what to do now, when it leaked the
0 Video - Rear Suspension Sag - Does It Really Matter?
0 XR-1000 restoration guide?
Last Post: JOHNNY YUMA
0 Single fire dual fire ignition
0 1979 iron head sportster exhaust
0 Help & advice needed
0 Wire wheel hubs
Last Post: LenC
0 teflon buttons or circlips?
Last Post: thefrenchowl
0 Sources for new/used cast front wheels
Last Post: 84rzv500r
Last Post: speedyrette
0 2008 xl1200c
Last Post: Tyler45
0 The Strociek Project
0 Best head casting for porting Question
0 Upper Support Bracket Installation
0 Where To Get Free Air
Last Post: RockerRider
0 My 99 883 c
Last Post: 99-883-c
Last Post: IvanIron
0 Engine oil getting into primary help
Last Post: andy2175m4
yeller1200, IronMick (79), painter (72), motobob883 (69), rickxx (67), MRCLEEN (49), Wetcheez (48), hello_shoes (41)
Old 24th March 2008
Alun's Avatar
Alun Alun is offline
Sportster/Buell Year: 1971
Other Motorcycle Model: Harley V-Rod
Alun is an unknown quantity at this point
Default Cleaning a Carb
I am restoring a '71 Ironhead and wondered if there was any tips and tricks for taking off/stripping/cleaning/putting back the carb?
If there's already a stickie then could you point me towards that. Cheers. Alun
Old 24th March 2008
1. Removing it from the bike should be straight forward. First thing when it is out is to check the pilot screw setting. Turn it all the way in until gently seated counting the number of 1/4 turns; then write this number down; then reset it.
2. I put mine in a vice to remove the screws, and for much of the following work. Wrap in a shop towel; close the vice gently taking extra care with the choke and throttle linkages. The vice is a needed extra pair of hands.
EDIT: This setup works better than putting the carb directly into the vice ...
3. I am very careful handling the float so as to not change the level. I use the official specs for setting the level as in the FM, and check it, every time i dismantle the carb, as the last thing before putting it back together.
4. The jets are made of brass, a soft metal that is easily damaged. Use an exact correct size screwdriver. I ground a medium flat blade screwdriver down to exact size on my bench grinder to access the slow jet.
5. The general appearance of the inside of the carb is not necessarily a good indication of its condition. It can look spotless and have clogged jets, or look cruddy and have clear jets.
6. I prefer to clean each individual part rather than soak or boil the whole carb in carb cleaner. But either way is good. Do not allow any solvents to contact any rubber parts [tip of needle, o-ring seal for bowl].
7. Make a list of all of the jets and passages for your carb using the carb manual or the FM for the bike. Then ensure that you can blow either compressed air or carb cleaner thru each one.
8. Remove the pilot screw and clean the parts and the passage. The passage contains in this sequence: pilot screw, spring, washer, o-ring. These are very small parts, especially the washer and o-ring. Usually the spring will easily fall out. One time i thought the spring was not in there because it would not fall out; i obtained a new spring and could not get it in! The technique for removing the washer and o-ring is to use a pipe cleaner: stick it in the hole, twist it around, remove it - you should see the washer and o-ring on the end of the pipe cleaner.
Remember that the purpose of the washer is to protect the o-ring from the spring and you will always get them back in in the correct sequence.
EDIT: Some carbs, noteably 1966 to 1978 Sportster carbs, do not have the o-ring and washer in the pilot screw passage.
9. Dismantle the accelerator pump assembly noting carefully the sequence and orientation of the parts. Clean and inspect the parts. Replace the diaphragm if it is cracked.
10. Check the float level then carefully put it back together. I personally find it very confusing trying to decide which way to bend the tang if it is not correct. If the fuel level is low is the float high or low? Do i need to bend the tang up or down? On the bench the carb is usually upside down, adding to the confusion. Sort all this out before making an adjustment.
Best to replace the original Phillips screws for the bowl with stainless steel socket head screws.
Old 24th March 2008
AMF Harley-Davidson's Avatar
AMF Harley-Davidson AMF Harley-Davidson is offline
Sportster/Buell Model: XL 1000
AMF Harley-Davidson is an unknown quantity at this point
Hi Alun
What Carb do you have? Is it the original Tillotson?
Bob
Old 24th March 2008
Alun's Avatar
Yes it is. I not too bad nick but looks quite "sooty"
Old 26th March 2008
I am giving this thread a bump as i made it a Sticky and edited my post #2 to include more detail.
Old 12th April 2008
diabloblanco's Avatar
diabloblanco diabloblanco is offline
diabloblanco is an unknown quantity at this point
Pretty good site with pictures on a Super G rebuild:
Thanks for the info!!!
http://www.hotrodsbikeworks.com/tech...ild/index.html
Old 16th April 2008
74chopster's Avatar
74chopster 74chopster is offline
Sportster/Buell Model: sportster 74chopster xlch
74chopster has disabled reputation
i cleaned my super b and now it turned to shit. it seems the varnish was holding it together. the throttle shaft obtained a major leak after cleaning. and im not going to buy the repair kit. im going to a super e shorty this time it has excelerator pump. so be carefull what you ask for lol
Old 3rd May 2008
Monte03's Avatar
Monte03 Monte03 is offline
Sportster/Buell Year: 1969
Other Motorcycle Year: 82
Default Carb Cleaning
Dismantle the carb down to the body and soak it in Mineral Spirits for a few days, you will be suprized at all the dirt in the bottom of the soaking container.
just let it sit.
I have also heard of guys blasting the body with Baking Powder..
Old 23rd June 2008
russzx6's Avatar
russzx6 russzx6 is offline
Sportster/Buell Model: 1000cc Ironhead Sportster
Other Motorcycle Model: 96 KDX200 Dirt Bike
russzx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to all
I always use acrylic paint thinners for cleaning up carb parts. .melts that fuel varnish right off. .but watch out it really gives rubber and gasket material a hard time
Old 1st July 2008
forumsnowboards1st's Avatar
forumsnowboards1st forumsnowboards1st is offline
Sportster/Buell Model: An old 74 iron head
Other Motorcycle Model: Honda cbr
forumsnowboards1st is an unknown quantity at this point
started on an original bendix carb that was in one of the junk boxes that got tossed in the back the truck when I bought the the 1974 iron head. it looked like it has never been mounted or used. but where the fuel comes in the brass piece was broken off. i tried drilling it out hoping go back in and pull the remaining treads with the needle nose pliers. this didn't work brass doesn't plyable enough and if I move up another size on the drill bit I'll be drilling the carb not the brass fitting. Also the darn brass screws wont come out so i can get the metal shaving that falling into the carb out. I need help any suggestion?
jon
