0 why you can't be seen
0 need help with 68 XLH
Last Post: mrmom9r
0 Oil pressure switch
Last Post: Edster
Last Post: Fivecats
0 What oil temp do you run
0 HSR idle mixture screw
0 Gear and brake linkage
Last Post: Hardtail28
0 Front deflection
0 Off Road Lights
0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 First start question
Last Post: Fivecats
Old 4th February 2015
betasom's Avatar
betasom betasom is offline
Sportster/Buell Model: Sporster
betasom is an unknown quantity at this point
Default Oil metal filter remove
Good evening Gentlemen,
as I wrote in Introduce Yourself section,
today I started in restore/repair my 1975 Sportster Ironhead.
Engine is stopped from 8 years. As the cranckcase was empty of oil, I filled it with 2 liters of white petrol to wash and remove the rest of old oil. Then I blowed with compressed air. Oil ways were obstructed partially - some "shit" is went off...
Now I want to remove the half spherical metal grid (red arrow in the pic) that works as oil filter, to clean inside its empty.
http://betasom.altervista.org/galler...nhead.jpg.html
What do I do to remove it?
Many thanks for any tips.
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Here's your pic:
Folkie
South East England Riders
Old 5th February 2015
big andy's Avatar
big andy big andy is offline
Sportster/Buell Model: xlch 73
Sportster/Buell Year: sold
Sportster/Buell Model #2: 1997 1200s
big andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond repute
The hole under the filter has a tiny round metal pin that holds it in use a magnet on the end of some wire to extract it or grab it with some pliers if you can
1997 1200s 1250 Hammer performance kit . Hammer performance billet inlet manifold .Hammer performance billet pushrod tube holders. energy one extra plate clutch kit . bronze oil pump drive gear upgrade
randy3934's Avatar
Andy's referring to the small hole on the gasket surface right below the screen, I take a small scribe and scratch away the peen spot that will keep the pin from coming out, then use a magnet to remove, I don't bother peening again as the cam cover and gasket won't let it come out anyway.
betasom's Avatar
Thank you Gent,
it works. I scratched the hole with mini drill, than get off the pin with a powerfull magnet.
The empty below ("little well" in italian) was fill of black oil mud.
White petrol wash and lots of air blow, now is like new. The gasket was broken and I replaced it with one of my self building.
