0 2009 Speedometer Wiring/Colors
Last Post: Gulf Coaster
Last Post: Firehawk
0 External breathing systems
Last Post: Firehawk
0 Hi From Atlanta
Last Post: barncat78
0 Which Battery?
Last Post: fafcpa
0 19'' Cast/Chrome Front Wheel
Last Post: knut
0 Sportster Cobra seat
0 Cylinder Head Temp. How hot is too hot?
0 Early 60's headlight "brow", "mount", "visor" or whatever you want to call it.
0 Right rear turn signal out 2002 XL1200C
0 Sonnax, Timken, Torrington
0 Sleeve cylinders?
0 Issues with my jiffy stand... HELP!
0 Any1 running this ignition??
0 Celebrating Sportsterpedia's Fourth Anniversary
Last Post: DéDé
0 Rear Sprocket for Belt
0 TC88A update ?
0 Rain pants
0 Changing stock Speedometer mount
Last Post: sarcvicious
Taipan (61), Harveyveepower (60), regoscar (51), kmm0000 (45), SmokeyDrifter (37)
Old 26th March 2015
sportsterdoc's Avatar
Default 2007-2013 wiring info
Not a substitute for complete schematics, but these connections and wire colors may be helpful:
2007-2013
ECM position numbers – purpose – wire color
1 blank
2 system relay gn/o
3 blank
4 blank
5 serial data link lgn/v
6 engine temperature pk/y
7 intake air temp lgn/y
8 front oxygen sensor (A) pk/o
9 jiffy stand switch (HDI only) gn/bn
10 power ground bk
11 coil, rear y/be
12 crank position sensor (-) bk
13 switched power w/bk
14 5V sensor power r/w
15 blank
16 blank
17 idle air control (A) high bk/o
18 idle air control (B) low bk/pk
19 fuel injector, rear gn/gy
20 blank
21 fuel injector, front w/y
22 blank
23 rear oxygen sensor pk/gn
24 throttle position sensor input gy/v
25 TMAP sensor input v/w (TMAP replaced MAP in 2010)
26 5V sensor ground bk/w
27 blank
28 power ground bk
29 coil, front be/o
30 crank position sensor (+) r
31 battery be/gy
32 blank
33 vehicle speed sensor input bk/be
34 blank
35 idle air control (A) low be/gn
36 idle air control (B) high bn/r
TSM/TSSM
1 battery bn/gy
2 ignition gy
3 serial data link lgn/v
4 neutral safety switch tn (formerly security indicator on 2004-2006)
5 left turn output v
6 right turn output bn
7 right turn input w/bn
8 left turn input w/v
9 starter relay control tn/gn
10 clutch control bk/r (formerly ignition enable switch on 2004-2006)
11 alarm signal lgn/bn
12 ground bk
Speedo (numbers are left-right)
12 blank
11 trip switch bk (to 8)
10 blank
9 fuel y/w (formerly blank on 2004-2006)
8 trip switch (to 11)
7 ground bk
6 accessory o/w
5 battery bn/gy
4 blank (formerly security on 2004-2006)
3 blank
2 data lg/v
1 ignition o
Tach
1 ignition o
2 data lg/v
3 blank
4 blank
5 battery bn/gy
6 accessory o/w
7 ground bk
8 blank
9 blank
10 blank
11 blank
12 blank
Fuses 2007-2009
Spare
Instruments o
Ignition g
Battery bn/gy
Lights be
Accessories o/w
P&A ignition fuse
Spare
ECM be/gy
Fuel pump o/gy
System relay
Start Relay
Spare
Fuses 2010-2013
Ignition g
Battery bn/gy
Lights be
Accessories o/w
ECM be/gy
System relay
Start Relay
Old 26th March 2015
That's good info to have as a reference--- Thanks
__o~~o__
IXL2Relax
Old 27th March 2015
I typed this, while looking at a schematic
If anyone notices a typo, please advise
