Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > VENDORS > NRHS - High Performance
Last Post: jammantoo
0 What is this?? 07 efi 1200 weird box
Last Post: norseXL
0 My Sportster basket case has arrived!
Last Post: VH5150
0 WTF Happened
0 Cylinder Piston kits
0 Diagnostic help
0 Tool Roll Help
Last Post: hexnut
Last Post: hexnut
Last Post: Matt397
Last Post: Coz
0 An iron head on Devil's Island
Last Post: spacecoast
0 84-90 lifter block bolt- what sort is it?
Last Post: Turbo Sporty 48
Last Post: jordan1200
0 05 and 73
0 Brake light stays on
0 S&S Stealth
Last Post: lucifer_mr2
0 Not charging issue!
Last Post: tvon
0 Iree's jukbox joint
Last Post: Sadsack
0 If you have European tilt
Old 24th January 2005
barry1967's Avatar
barry1967 barry1967 is offline
Other Motorcycle Model: 2005 FXD Chopper Blue
barry1967 is an unknown quantity at this point
I think you would need the 04 cover though due to the tapered design.
Stage 1
Metz 880s
V&H pipe
95 inch and more very soon.
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
No worries Sham, there's no problem with posting here. All I ask is that if a person seeks customer service, please call the shop. We try real hard to provide good service but a web forum is not the place to do it. Questions about our products is no problem though.
Anyway, to answer your questions:
1. It'll use the stock cover, insert, & cover screws, that's it.
2. The kit will consist of the filter element and CNC machined backplate with standoffs. Like many air cleaner vendors, we opted not to include the carb bracket or breather stuff because there are so many ways to do that and everyone has their own ideas, from cheap and simple to elaborate and expensive. For example, for the carb bracket you can go simple black for $10 or fancy chrome for $24. For the breathers, you can use simple fittings like a Buell uses, or go with banjo bolts, or an over-the-top chrome tube (pictured above), or a Devonator, or "Dickheads", or about a thousand other ways to do it. I don't want to add cost to the air cleaner kit including hardware that the customer may or may not want.
aswracing's Avatar
Sure, you can bolt these things on back and forth all you want. The only difference in the air cleaners is that one is designed to accomodate the 91-03 ham can cover and the other is designed to accomodate the 04-05 cover.
barry1967's Avatar
The carb support brackets, What do they look like? They can't be seen in the pictures and was just wondering. I might want the black one.
Old 25th January 2005
aswracing's Avatar
Here's a picture of the black one. The chrome one looks a little different (besides being chrome), I'll get you a picture when I get a chance.
txsporty's Avatar
txsporty txsporty is offline
Other Motorcycle Model: FLHTCU
Other Motorcycle Year: 2008
txsporty is on a distinguished roadtxsporty is on a distinguished roadtxsporty is on a distinguished roadtxsporty is on a distinguished roadtxsporty is on a distinguished road
Nice Looking, will you be making some other type of cover for your A/C other then having to use the "Ham Can"??
Shamdog's Avatar
Shamdog Shamdog is offline
Sportster/Buell Model #2: Dyna Low Rider
Sportster/Buell Year #2: 2004
Shamdog is on a distinguished roadShamdog is on a distinguished roadShamdog is on a distinguished roadShamdog is on a distinguished road
The reason for my question is that now I have a hypercharger. I figure that when I remove it I will have no stock components except the CV carb itself. So, I'm trying to figure out what stock parts I will need to go with the Hurricane AC and install kit.
Thanks
'00 1200 VC (Very Custom)
Daytona Ignition / SE Round AC / HSR 42 / NRHS Stage 2 XB Heads / Hurricane 10.5:1 pistons / SE .536 Cams / RB LSR 2-1 / Ghost Flames / Bling and...well, you get the picture
aswracing's Avatar
Actually, yes, there's a plan in the works to offer the 91-03 version with a carbon fiber ham can cover. Problem is, the covers are expensive. I'm still working the issue, no point doing it unless I can make it economically viable.
There used to be a company that sold a similar kit for Buells, called "Frontier", with a CF ham can. The backplate was stamped aluminum without the perimeter recess, but it had a big venturi ring like these, and a 3" element with the CF ham can. So it was a little less costly to make than mine, but it sold for about $300, and I'm guessiing that CF cover was a big part of the reason. Even the Buell race kit (similar deal, stamped backplate, little plastic venturi ring, 3" element, CF cover) was nearly $300 (originally they came out at $200 but Buell raised them). BTW, the Frontier significantly outperformed the Buell Race Kit filter every time I tested them, and the only real difference between them was the venturi ring. It makes a difference!
barry1967's Avatar
Thanks, the black one would do my fine.
  #30
Old 26th January 2005
shooter shooter is offline
Sportster/Buell Model: 1200 Roadster
Other Motorcycle Model: SE 103 RoadKing
shooter is an unknown quantity at this point
I got mine last week. It looks like a great breather. Can't wait to get it on a dyno. Now if only I had a set of heads back from my tuner to bolt it to. Trying to get my package together before Daytona. If not, I will have to drive my old slow 103 Roadking.
Shooter
Similar Threads
HurricaneFlow Air Cleaners jimmyheadgear Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 27 29th June 2009 05:53
HurricaneFlow 3" for 2004 gilx Product Reviews 5 29th May 2005 05:06
HurricaneFlow Air Cleaner Came Today raysheen Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 8 14th March 2005 00:25
Spacing on Breather Holes-NHRS HurricaneFlow Breather shooter Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust 13 8th February 2005 00:22
