Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE ZONE > Buell Motorcycle Bottom End
0 TC88A maps for 1250 Sporty
Last Post: Yellowstone Kelly
Last Post: Diogenes415
Last Post: lugster
0 Feeling in trouble.
0 Cylinder Piston kits
0 1967 XLCH stroker project
0 Diagnostic help
Last Post: BradX13
0 If you have European tilt
7 Long Road Trip advice
Last Post: 38mini
Last Post: MatHormell
Last Post: kkbii
0 first harley- help!!
Last Post: r4fthrs
0 PACK YOUR BAGS SALE! Take 10% off 'Voyager' Series Luggage
Last Post: BILLETPROOF
Last Post: lo-rider
Last Post: runingmouse
0 Will you help out The XL Forum?
Last Post: bplinson
0 spoke nipple tool?
Old 1st April 2008
Johnny Ableto Johnny Ableto is offline
Sportster/Buell Model: Buell X1
Other Motorcycle Model: Yamaha TDM850
Other Motorcycle Year: 2000
Johnny Ableto is an unknown quantity at this point
Default torque/cams?
My X1 doesn't seem to have the bottom end and mid-range torque that my old 1988 sportster had. I've heard that fitting stock sportster (D grind?) cams will increase the bottom and mid and sacrafice top end.
Has anyone done it?
Any ideas?
I don't care what kind of helmet Kenny Rogers wears.
Old 1st April 2008
LLOYD883's Avatar
LLOYD883 LLOYD883 is offline
Sportster/Buell Model: xl883c
LLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud of
The stock D cams are fine for mid-range torque but if you really want low-end go for the W cams, big difference. The W's increase the cranking pressure (compression) quite a bit as the intake valve closes at ±26*ABDC vs ±41* for the D's (which is what lowers the torque peak from ±4500RPM to ±3500) and I am also told that they add about 5HP.
2005 883XLC - 42 slow jet, 2 1/2 turns out - N65A needle shimmed 0.030" with stock 170 main jet - 07 1200 W cams - mildly ported stock heads - Arlen Ness Big Sucker air cleaner with HD round nostalgia cover - Khrome Werks 3" tapered slip-ons - SE 1200 ignition module - microTach - Mustang "solo tripper" seat - 12 1/2" Progressive 412 chrome rear shocks.
Old 1st April 2008
Thanks for that Lloyd883. Thats good info. John.
Old 2nd April 2008
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
What exhaust are you using?
Your stock cams have quite a bit of overlap, which makes them very sensitive to the exhaust system. An exhaust system that pushes back in the midrange will wipe out midrange power. The factory exhaust does this terribly.
You can make lots of bottom end and midrange with your stock cams.
Old 2nd April 2008
Using supertrap exhaust. It's not that the bottom and midrange is bad but nowhere near as good as my old sportster, I wonder if the difference could be the S & S shorty G ( I think ) and the steep advance curve of the 1988 1200.
Thanks for the reply,
John
Old 2nd April 2008
A super G is WAY TOO BIG of a carb for a stock bore X1. You should have an E.
Old 2nd April 2008
The carb was on the old sportster (the X1 is injected) and it may have been an E.
Thanks for reply,
John.
Old 20th May 2008
Quay Quay is offline
Sportster/Buell Year: '07
Sportster/Buell Model #2: Buell XB12Ss
Sportster/Buell Year #2: '09
Other Motorcycle Model: Hayabusa
Other Motorcycle Year: '99
Quay is a jewel in the roughQuay is a jewel in the roughQuay is a jewel in the roughQuay is a jewel in the roughQuay is a jewel in the roughQuay is a jewel in the roughQuay is a jewel in the roughQuay is a jewel in the roughQuay is a jewel in the roughQuay is a jewel in the roughQuay is a jewel in the rough
I'd say by all means, insure your engine is tuned properly and exhaust correctly selected before making rash guesses. The weight of the Buell should help it leap right out, compared to a stock Porkster. Few machines make it down the 1/4 mile in significantly less time than others, by being "whimpy" in the first 60 feet.
