0 Diagnostic help
Last Post: BradX13
Last Post: jordan1200
0 Stock 883 cold blooded
Last Post: Diogenes415
7 Long Road Trip advice
Last Post: gunwish
0 Leaks
Last Post: Steven2142
0 Value of a Boattail?
0 z bars
Last Post: 201648Rider
Last Post: 72 Ironhead XLH
2 Humble pie
Last Post: Sprtstr1200s
0 Spring Seat Brackets?
Last Post: RussW
Last Post: gravydog
0 New to Harley
0 79 ironhead
0 Back in Sporty Land
0 1967 XLCH stroker project
0 Head gaskets.
Last Post: 883openpipes
0 99 1200s clutch drag
Last Post: NZstu
0 79-83 dual disc fork spring length
Last Post: Reverend G
0 Check engine light, again
Last Post: lazyb8s
Old 4th April 2008
dustin.marple dustin.marple is offline
Sportster/Buell Model: 883 Sportster
dustin.marple is on a distinguished roaddustin.marple is on a distinguished road
Default 412 Installation Question
Just received my 11.5" Heavy Duty 412's today and installing tomorrow. Anybody who has installed aftermarket shocks, is it ok to use the same bolts that came with the bike on the shocks for my new shocks? I heard that the bolt may go bad once taken off the bike. Has anybody used different bolts and nuts than what come stock on their bike when installing new shocks?
Thanks
Old 4th April 2008
samppa's Avatar
samppa samppa is offline
Sportster/Buell Model: XLH883H'97
samppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of lightsamppa is a glorious beacon of light
I've always used the original hardware when replacing shocks and haven't had any problems... Maybe new bolts & nuts could be in order but I'm not sure why stock bolts would go bad if you don't do anything funny with those.
Kunnon morsettaja piikkaa molemmin käsin.
Old 4th April 2008
ed_in_az's Avatar
ed_in_az ed_in_az is offline
ed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond repute
Unless the stock bolts are stripped, stretched, broken, or bent there shouldn't be any problem re-using them. I did.
2008 Nightster 1200 Convertible: Touring/Bobber SE Stage I
