Last Post: DéDé
0 Rocketmangb
Last Post: DéDé
0 Clutch Replacement
Last Post: clif02
0 Massachusetts 2022
0 What's up with this turn signal?
0 Rubbermount a pre 2004
Last Post: RON BAYLESS
0 Tank flush
0 Getting old is a bitch!
0 85 Ironhead, Kiffy Stand Question
Last Post: eddie XLX
0 Turn signals stopped blinking
Last Post: RandallM
0 Allegheny National Park III
Last Post: skien
0 My new deer rifle
Last Post: kiwicafesporty
Last Post: 11B40
Last Post: speedyrette
Last Post: shtbskt
Last Post: Brad
0 Sportster S on the dyno
Last Post: Fivecats
0 1967 on FaceBook. Florida.
Old 18th October 2015
norseXL's Avatar
norseXL norseXL is offline
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1994
Lightbulb Breathing thru the cam?
Now with the winter coming and my car finaly fixed, there migh be at last some Sportster related projects coming my way.
I am going to split the cases on the '86 to put in new cam bushings and may do something I've been thinking about for a while:
Let the engine breathe thru one of the cams, thereby use the rotation to fing the oil out of the air, preventing oil mist coming out when going fast over an extended period.
This will not be something I will start with before well into winter, but the discussion may wery well start now
Tore
"In the design of an internal-combustion engine, as in all creative work of this nature, the æsthetic side must not be overlooked.
In the first place, beauty of form and of proportions is in it self an admirable guide to mechanical correctness;
for mankind has come to regard as beautiful that which is mechanically correct, whether it be in nature, in architecture, or in enginering."
Sir Harry R. Ricardo
steelworker's Avatar
Other Motorcycle Year: 2016
Have you been at the mead, Tore?
This should be interesting - something to occupy the long winter evenings.
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
You don't have to split the cases to do that...interesting idea however.
Old 19th October 2015
norseXL's Avatar
Have to split the cases to ream the cam cover bushings Iree,
since I have no right side left-over case half laying around.
norseXL's Avatar
No mead Myles
Yep it was the breathing on the BMW Rotax twins that gave me the idea,
they have holes on the outer edge of the gear for the water-pump,
that gear sits on the end of the innlet-cam.
Exit is at the center of the cam, never se any oil in the air-box of those.
Tore
I guess I do not understand what it is you are trying to do?
norseXL's Avatar
The tought is to let the air come into the cam thru an opening as far from the center of the cam as possible,
to let sentripetal force fling the oil out of it (the air).
Then let it exit the engine thru the center of the cam,
via an extension through the cam-cover and then through a reed or umbrella valve.
Tore
Now I understand. Evo big twins use a similar system. What might be even better is to try to adapt the S&S reed valve system. Just not sure where you would put it:
norseXL's Avatar
Not realy the same as I'm trying to do, sorry...
Tore
I Guess i do not understand how you could breather thru a cam and also have an umbrella or reed valve then? Do you have a pic of the other bikes system you talked about?
