Last Post: DéDé
0 Rocketmangb
Last Post: DéDé
0 Clutch Replacement
Last Post: clif02
0 Massachusetts 2022
0 What's up with this turn signal?
0 Rubbermount a pre 2004
Last Post: RON BAYLESS
0 Tank flush
0 Getting old is a bitch!
0 85 Ironhead, Kiffy Stand Question
Last Post: eddie XLX
0 Turn signals stopped blinking
Last Post: RandallM
0 Allegheny National Park III
Last Post: skien
0 My new deer rifle
Last Post: kiwicafesporty
Last Post: 11B40
Last Post: speedyrette
Last Post: shtbskt
Last Post: Brad
0 Sportster S on the dyno
Last Post: Fivecats
0 1967 on FaceBook. Florida.
Old 19th October 2015
Like Ranchero says the center of the cams is probably a lot softer than the outer hardened part. i just could not get to it with a cobalt drill bit.
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
The chances of either carbide or hss drills working well are not high...they tend to walk over the required distance. Gun drill (good) or EDM (best) are better processes.
You do not want to change to properties of the case hardening, which conventional even with through coolant, drilling would do.
Old 20th October 2015
norseXL's Avatar
norseXL norseXL is offline
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1994
I'm not sure how your cam breather would work with the differential pressure spikes from the pistons moving up and down together. Oh, btw, the cam should be pretty soft in the center. A carbide end mill should eat through the induction hardened section @ .020"
[/QUOTE]
This set-up is just to separate the oil from the air, I will use a reed valve externaly.
...and btw, end mill was purchased today so I hope to find time to put a cam in the lathe soon.
"In the design of an internal-combustion engine, as in all creative work of this nature, the æsthetic side must not be overlooked.
In the first place, beauty of form and of proportions is in it self an admirable guide to mechanical correctness;
for mankind has come to regard as beautiful that which is mechanically correct, whether it be in nature, in architecture, or in enginering."
Sir Harry R. Ricardo
Old 31st October 2015
norseXL's Avatar
Tungsten carbide worked like a charm!
High speed slow feed and thru the hard layer it went.
Unfortunately I was too impatient and instead of switching to an cheep kobolt drill-bit for the soft part,
I feed to fast with the expensive tungsten one and it snapped on me.
Well, well, Amazon have more of them...
Here's the one that worked, left hand "tread" on it also, so a wery good tool for extracting broken bolts, like exhaust-studs.
Tore
Old 1st November 2015
Um...I don't know what the one you had looks like but the illustration above is a rh twist.
Joe
norseXL's Avatar
Joe
Yep, you are absolutely right about the picture, it was just the illustration pic that Amazon used...
Tore
Old 12th November 2015
norseXL's Avatar
Progress...
Tore
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
I think you should rifle it ... make a little pump out of it, to suck the air out of the crankcase.
Click Here to Contact Me
cannot wait to see how this works!!
norseXL's Avatar
@ Aron
I guess the pressure from the pistons will be enough for that, this will be the only breathing for the engine.
I will also crimp on two discs to make the innlet diameter larger than the diameter of the cam to make greater sentrifugal forces for separating the oil mist out.
Tore
