Last Post: Aden
0 THE Trainspotting Thread
0 48 Handling
Last Post: 201648Rider
0 Mid's or rear sets
Last Post: gusm2
Last Post: 72 Ironhead XLH
0 Blow thru setup
Last Post: Sideshift92
0 -75 ironhead, My first HD
Last Post: blindfredy
0 91 oil in cam cover
0 Safe to run 2 master links?
Last Post: Reverend G
Old 6th April 2008
fnagy82 fnagy82 is offline
fnagy82 has disabled reputation
Cool 06 1200C dyno results need help
I had my bike dyno yesterday and I having problems with the air\fuel ratio. I t would spit and sputter when he would first start the dyno run and the pick up and smooth out. I’m not sure what adjustments the carburetor needs at this point. The engine is stock except for the SE slip ons, N4 Andrews cams, HSR42 carb. I did change the main jet from a 160 to a 155 today. The top dyno run is mine and the bottom one was for comparison
Here are my Specs.
A/C Arlen Ness Big Sucker
ENGINE: 2006 1200c
EXHAUST SE slip on's
INGNION Stock
LOWER END: Stock
CAMS Andrews N4
CYLINDERS: Stock 1200
CARBURETER Mikuni HSR 42
PISTONS: Stock
HEADS: Stock
HP 81
TQ 78
Old 6th April 2008
rottenralph's Avatar
It is a little hard to read the a/f looks like it went a little lean between transitions between jets. I know nothing about Mikunis so I can't comment about jetting or adjustment. The h/p looks about right.
Old 8th April 2008
Anybody have any comments on the hsr 42
Old 8th April 2008
rfranz1952's Avatar
rfranz1952 rfranz1952 is offline
Sportster/Buell Model #2: XLX
Sportster/Buell Year #2: 1985
Other Motorcycle Model: Yamaha Vino 125
rfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nice
Decent numbers. What A/C?
2005 XL 1200 Custom; NRHS 1250 Conversion, 10.5 - 1; Stage 2 Heads; SE 536 Cams; Jim's Hydrosolid lifters; NRHS adjustable pushrods; S&S Roller Rockers; Crankshaft by Darkhorse Crankworks; HurricaneFlow A/F; Hurricane Oil Filter; Mikuni HSR-42; S&S Intelligent Spark Technology Ignition; RB Racing LSR exhaust; Front and Rear Progressive Suspension; Oversize front tire; Superbrace Fork Brace; Speedway Microtach, lots of other bits and pieces.
THE $16,000 Sportster!
Old 8th April 2008
robert's Avatar
robert robert is offline
Sportster/Buell Model: xl883c
robert has a spectacular aura aboutrobert has a spectacular aura aboutrobert has a spectacular aura aboutrobert has a spectacular aura aboutrobert has a spectacular aura aboutrobert has a spectacular aura aboutrobert has a spectacular aura aboutrobert has a spectacular aura aboutrobert has a spectacular aura aboutrobert has a spectacular aura about
Stock air cleaner?
[SIGPIC][/SIGPIC]Pretty Boy Robert of the Hungry Horses MC
Old 8th April 2008
blakjak's Avatar
blakjak blakjak is offline
Sportster/Buell Model: Honda CBR 929RR
blakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura aboutblakjak has a spectacular aura about
Looks like right around 1700-1800 there's a hell of a lean spot. Is that right around where the spit and sputter is? If so, you narrowed down you're problem a little bit. I too have no experience with the Mikuni. I would think that it's the spot where you're transitioning from the idle circuit to the full throttle circuit if Mikuni's have the same setup as a CV. If that's the case, you can fatten up the slow jet and see what it does for you.
Hopefully someone who's actually tuned with one of these will chime in here and help out.
Old 8th April 2008
The air cleaner is a Arlen Ness Big Sucker
