0 Rocketmangb
Last Post: seajay
0 Tank flush
0 Getting old is a bitch!
0 85 Ironhead, Kiffy Stand Question
Last Post: eddie XLX
0 Turn signals stopped blinking
Last Post: RandallM
0 Allegheny National Park III
Last Post: skien
0 Clutch Replacement
0 My new deer rifle
Last Post: kiwicafesporty
Last Post: 11B40
Last Post: speedyrette
Last Post: shtbskt
Last Post: Brad
0 Sportster S on the dyno
Last Post: Fivecats
0 1967 on FaceBook. Florida.
0 High beam not working
Last Post: joe s
Last Post: 84rzv500r
Old 17th June 2008
Ralphthe3rd's Avatar
Ralphthe3rd Ralphthe3rd is offline
Sportster/Buell Model: 883R
Sportster/Buell Model #2: Buell P3
Other Motorcycle Model: Ninja650R traded for 883R
Ralphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to beholdRalphthe3rd is a splendid one to behold
Actually this is a very acute problem with those who speed shift their bikes, and (tube frame) Buells were more prone to this failure, but Sporties aren't immune ! BTW- when they redesigned the whole motor for the rubbermounts in '04, they totally relocated the detent plate and it's part of the shift drum now, and it's now longer even located in the primary, it's inside the cases...at least thats what I've gleaned from the service manual pix.
PS- I love my '07 Rubbermount
~Ralph (gonna try not being so Feisty)
*Former- AMA N.E. District 2 Flattracker #15u '74-'84
Old 18th June 2008
mrbreezeet1's Avatar
mrbreezeet1 mrbreezeet1 is offline
mrbreezeet1 is on a distinguished roadmrbreezeet1 is on a distinguished road
I understand you have to split the case to get to the tranny now. And they did away with the trap door.
I take it that means removing the motor from the frame?
Tony
Old 18th June 2008
Arrow thats true, but....
The tranny is built so well now, I never heard of one single case that a rubbermount has needed ANY tranny work, and I'm even talkin ones that have already done 100,000 miles !
Yeah sure the trap door was convenient, but 98% of all other bikes sold today- DON'T have trap doors ! Besides, most solid mount (Evo)XL riders never put on enough miles anyway, to need any tranny work done thru the trap door. I think the Trap door was more a hold over from the iron head days, when trannies weren't built all that well. BTW- all the Buell XB's don't use a trap door either.
Tony
Old 6th August 2016
BlackBikeDave's Avatar
BlackBikeDave BlackBikeDave is offline
BlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant futureBlackBikeDave has a brilliant future
old old thread with no ending..lol..what did you ever use in place of the stock detent clip. or how do you properly install the OEM clip? anyone got tips and pics?
Jerome 'Kid' Campo - 2/27/13 RIP "and I Ride like the Wind..To Be Free Again"
Old 6th August 2016
MatHormell's Avatar
MatHormell MatHormell is offline
Sportster/Buell Model: XL883R
Sportster/Buell Model #2: Buell XB12R
Other Motorcycle Model: Yamaha
MatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond reputeMatHormell has a reputation beyond repute
Ultimate fix for the shitty design with the circlip.. thread the shaft and use a lock nut
Sent from my SAMSUNG-SM-G935A using Tapatalk
HAMMER PERFORMANCE 90 Ci
CP .500 Dome Pistons
Axtel Cast Iron Cylinders
HAMMER PERFORMANCE .600 Cams
1.725 Ratio S&S Rocker Arms
HAMMER PERFORMANCE Intake Manifold
HSR 48 Miunki
XR1200 Crank Conversion W/ Case Mod 34T
HAMMER PERFORMANCE Sledge+ Head Work
2.020" Intake and 1.630" Exhaust Valves
Conical Valve Springs
S&S Premium Lifters
HAMMER PERFORMANCE Billet Push Rod Bases
Barnett Clutch Hub With Scorpion Clutch
Dynatek 2000i
R&D MOTORSPORTS- TRANSMISSION WORK-REM ISF
WorldWideBearings
Patriot Defender Exhaust
Old 6th August 2016
super duper +1 red tiger, that is the cat's meow for the drum. the e-clip can fail also. when my 01 xls spit the detent, it was steel and was replace with steel so it is still around. what I used was a thin ss washer and spiral ring, there is no gap to work against. if you can not find one, I also used ss safety wire with great success but must be correctly installed.
Old 7th August 2016
[QUOTE=MatHormell;5424491]Ultimate fix for the shitty design with the circlip.. thread the shaft and use a lock nut
Sent from my SAMSUNG-SM-G935A using Tapatalk[/QUO
How did you do that? Looks great and I would not give that another thought after putting the primary back together.
Old 7th August 2016
MatHormell's Avatar
[QUOTE=BlackBikeDave;5424650]
Mark at RD motorsports did it.. It's solid dude.. Doesn't move at all
Old 7th August 2016
MatHormell's Avatar
The baker drum is the same way as well I believe
Old 12th August 2016
I'd love if you posted a picture of the set up you used. I spent more time than I care to tell anyone fetching various sized washers and e clips from every local place I could find. Nothing worked for me and no one heard of the spring clip you are talking about. I decided to just clean everything real good and use the red loctite and the factory (kooky clip). If I ever have to get in the tranny again I am taking that shaft to a machinist and get that end threaded.
