Keep & Kill
4th October 2016
Posts: 3,034 Sportster/Buell Model: xlh 1000 69 79 xlch Sportster/Buell Year: 1977 Sportster/Buell Model #2: 80 FXE 82FLH 83FXR Other Motorcycle Model: 78FLH 79xlch 96xl 79xlh
36 mm zenith bendix
anyone running a 36mm bendix zenith on a 1,000 cc ironhead? went to rebuild one of my swap meet finds and discovered it's 36mm. will it run good?
4th October 2016
Also, anyone looking for any 79 xlh parts? picked up a pair for cheap with titles.
4th October 2016
Posts: 1,391 Sportster/Buell Model: xlh Sportster/Buell Year: 1974
I can tell you about some of the differences between the 38 and 36 bendix that I have.
The 38 is what came stock on a '74 xlh. The 36 was givin to me and I don't know where it came from and I've never used it.
Aside from the venturi size the other main difference that might affect the way it runs is the number of secondary idle discharge ports. These are the holes that get uncovered by the throttle plate at part throttle settings.
The 38 has 3.(in addition to the idle adjustment screw hole).
The 36 has 2.(in addition to the idle adjustment screw hole).
The air cleaner screw bosses on the 36 are smaller and I've heard prone to breaking.
The 36 does not have a bowl vent hole that the 38 has. I can't see why it would need it though.
The 36 should have more air velocity thru the venturi but flow less total CFM.
So to answer your question- will it run good?
Sorry, I don't know.
4th October 2016
Reformed Savant
Posts: 9,457 Sportster/Buell Model: xlch Sportster/Buell Year: 1961 Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 1970 Other Motorcycle Model: XL CE Tribute Other Motorcycle Year: 1977
It was only standard equipment for a year. Must have been a reason. Could your bike run fine on it? Probably.
4th October 2016
Posts: 3,035 Sportster/Buell Model: XLCH Sportster/Buell Year: 1977
smaller venturi equals better throttle response, but, a Possible [possible] loss of top end [WFO only] performance.
For putting about, I always choose a Smaller [relatively] venturi. which, in todays world a 38 already is.
YMMV
But, I bet most would Never know the Difference...Honestly.
4th October 2016
Posts: 812 Sportster/Buell Model: Sportster XL1200s Sportster/Buell Year: 1999
Idle discharge ports/ A friend had a new '72 XLH, his Bendix had an "A" stamped on it. I had a new '73 XLCH and had a "B" stamped on it part number. His carb only had 2 ports, mine had 4 ports if I remember correctly.
21st September 2019
this post was from a few years back hahaha, I did use that carb, it has adjustable main, I put it on a 74" shovelhead, runs just fine, starts really easy with kicker, don't notice any power loss at WOT, runs right up to 5,550 rpm and still climbing in 4th. should run fine on a ironhead.
21st September 2019
Posts: 267 Sportster/Buell Model: XLH Sportster/Buell Year: 67
What main and idle tube did you use or what was in it?
22nd September 2019
Posts: 116 Sportster/Buell Model: XLH Sportster/Buell Year: 1973 Other Motorcycle Model: Honda CB550 Other Motorcycle Year: 1974
36mm Bendix
I have a Bendix 36mm with 4 holes on my 73 XLH.
22nd September 2019
