0 Tried starting the bike this morning, batter charged, but bike wont turnover?
Last Post: Four Speed
0 lucas oil additive....
Last Post: gpydeski
0 Modified heads
Last Post: gpydeski
0 How to convert my dual disc '79 to a single 11.5" disc front end
Last Post: mikethebike61
Last Post: seajay
0 900 dual carb front head
0 1981 ironhead xlh PROJECT
Last Post: roadsterboy
0 Hi from NY state
Last Post: Jarlaxle
0 Do people notice your bike?
Last Post: brettxlch
Last Post: CT XR rider
5 Why Are You Still Married?
0 Oil Tank Cap doesn't fit right
0 New Photo Challenge: Show Us Your Bike Next to a Lighthouse!
0 03 sportster front muffler Stud nut Thread size?
0 Runs rough on highway.
0 Spectro STL 75W140
Last Post: 2cvandy
0 WTF Happened
0 Oil Analysis?
Last Post: Trailhawk750
0 JACKHAMMER 570 Cams!
5 Summer time heat
Last Post: Kbetts
0 NEW CRANK OPTION for 91-03 OWNERS: XR1200/Buell XB Crank Retrofits
0 Air Filter Soaks With Gas
mailmanjohn (52), 93customsporty (52), markmopar (52), ironheadTX (48), Austin-W (47), dcarterjr (47), MaX_01 (35)
Old 23rd October 2016
valvebeater valvebeater is offline
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1975
Other Motorcycle Model: FLH
Other Motorcycle Year: '82
valvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of lightvalvebeater is a glorious beacon of light
Default $10 mainshaft race line hone
Once I got it set up and bedded in, it took me about 8 tries at about 3 munites honing and testing to remove about .003 in about 45 munites for a perfect fit. Vid and pics self esplanitory but i will gladly answer questions.
Gonna try this link:
http://s1044.photobucket.com/user/wzuccarello/story
OK I see them in the sidebar.
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Model #2: Xl 883n
Sportster/Buell Year #2: 2010
Other Motorcycle Year: 1977
Video didn't load here.
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
What is that thing? Some kind of homemade lapping tool?
Yes exactly, I referred to it as a hone in the title. It is actualy is a home made line lap.
doodah man's Avatar
the short end goes to the drill chuck? what does the other end ride in, the clutch gear?
The short end goes in the drill chuck, tje long end goes through the clutch gear and rides on a slightly dressed down 1/2" male thread pvc fitting screwed in place
( fitting shown in other pictire). Also there is an angle iron stop there across the c g bore for a depth stop to stop the lap's cutting area just past the the bushing.
Turning the nut next to the chuck causes expansion control.
http://i1044.photobucket.com/albums/...psqb6tj1r0.jpg
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
How do you ensure your 'stones' are parallel as you remove material from the race? They look like they are tapered when expanded.
Yes the split cap is tapered and is adjusted by turning the end nut. The only part in hard contact and doing the work is about a 1/8" band at the edge of the split cap. Once the cap is forced tightly to the race and spun with lapping compound, the softer copper quickly conforms to the race.
In use, you slow stroke it completly through the race each pass. You can feel the work and tell if is going out of parallel or barrel shaped at all by the torque of the drill, and spend more time at the tighter area if needed.
