Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Lubrication and Lubricants
Lubrication and Lubricants You guessed. Here is where everyone can argue over oil.
5 Nightster tyre type "-" or "B"
Last Post: b0fh
Last Post: corndog76
0 Issues with my jiffy stand... HELP!
0 2009 Speedometer Wiring/Colors
0 Hi From Atlanta
0 Banjo bolt sizes for front brake line.
Last Post: slamtry
0 roadside belt change
Last Post: jazzman
0 Too HOT to ride?
Last Post: Kbetts
Last Post: mrbreezeet1
5 What Color Helmet is Most Noticable?
0 Sonnax, Timken, Torrington
0 Need Float for Zenith, or a replacement Zenith
Last Post: Gulf Coaster
0 External breathing systems
Last Post: Firehawk
0 Which Battery?
0 19'' Cast/Chrome Front Wheel
Last Post: knut
0 Sportster Cobra seat
0 Cylinder Head Temp. How hot is too hot?
0 Early 60's headlight "brow", "mount", "visor" or whatever you want to call it.
0 Right rear turn signal out 2002 XL1200C
0 Sleeve cylinders?
Taipan (61), Harveyveepower (60), regoscar (51), kmm0000 (45), SmokeyDrifter (37)
Old 11th November 2016
mrwilliamfox mrwilliamfox is offline
Sportster/Buell Model: XL883R
mrwilliamfox is a glorious beacon of lightmrwilliamfox is a glorious beacon of lightmrwilliamfox is a glorious beacon of lightmrwilliamfox is a glorious beacon of lightmrwilliamfox is a glorious beacon of lightmrwilliamfox is a glorious beacon of lightmrwilliamfox is a glorious beacon of lightmrwilliamfox is a glorious beacon of lightmrwilliamfox is a glorious beacon of lightmrwilliamfox is a glorious beacon of lightmrwilliamfox is a glorious beacon of light
Default Redline Gear Lube Shockproof Disaster
Check out this story (Nov. 8 2016). I took my 2007 883 Roadster to my local independent Harley Mechanic for a clutch inspection. They discovered a slimy, gummy mess inside the primary case, contaminating the clutch and gearbox. I used 80W Redline with Shockproof based on the recommendations from the Redline & Cyclegear website.
https://www.redlineoil.com/product.aspx?pid=112& "Popular for Sportster V-Twin transmissions"
Should have asked the experts first. My mechanic thinks it's the "additive" in shockproof that gummed up the works...what a mess. He replaced the factory clutch with a Barnett Carbon Fiber clutch pack and BelRay lube for sportsters. Check out the images in the hyperlink.
I'm waiting hear back from the managers at Redline about the "fix" not just the feedback I got from the call center representative.
https://photos.google.com/album/AF1Q...mtHIUSCZqbgRAG
hexnut's Avatar
hexnut hexnut is offline
Sportster/Buell Model: Sportster Superlow 1250
Sportster/Buell Year: 2014
hexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond reputehexnut has a reputation beyond repute
Don't know about Red Lines web site but Dave the Red Line tech sent me an email...
Thank you for contacting Red Line Oil, in the shared Sportster primary/transmission the 75W90 is recommended, a product that has been used extensively and performs well.
The 75W90 is the product we have have used for a number of years with very good results in Sportster/Buell transmissions, matching the viscosity and type fluid called for.
The 80W Motorcycle Gear Oil is a lower viscosity than called for, the ShockProof gear oils can due to their unique characteristics could cause sticking of the Harley clutches.
The 75W90 would be preferred and recommended over 80W Motorcycle Gear Oil in these applications.
There can be issues with some GL-5 gear oils in certain applications. Some can be corrosive to brass, bronze or copper, not an issue with our GL-5 gear oils, they don’t cause corrosion, pitting or metal removal. In a synchro equipped transmission the friction modifiers contained in many gear oils can make them too slippery, though not the case in a motorcycle transmission with dog rings.
So if you want the right viscosity and dont want to worry about it damaging anything, go with Redline
2014 Sportster Superlow, Hammer 1250, smash head work, 560 cams, S&S rockers and lifters. ported throttle body and intake,
Hammer crush air cleaner, Barnett clutch
Tuned by Power Vision
Supertrapp Supermegs exhaust
1200 gearing, super brace
Progressive suspension front & rear
ReddTigger's Avatar
so you used the wrong fluid.. ?
States I've Ridden in
71.3 hp 70.8 tq
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Yeah, I learned first hand not to use Shockproof in a Sportster back in 2002 ...
This sludge was mainly concentrated in the clutch, although there was some of it everywhere. What a mess.
Click Here to Contact Me
splineman's Avatar
splineman splineman is offline
Other Motorcycle Model: Honda GB400
Other Motorcycle Year: 1987
splineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond reputesplineman has a reputation beyond repute
Considering the mess the shockproof has caused in the 2 bikes in this thread you would think Redline would be more explicit in telling people not to use it in the sportster, both online and in correspondence.
In other words i'm not convinced the OP has been negligent in oil selection.
We should always use a product explicitly labelled to be used in a Sportster, or alternatively for shared gearbox, wet clutches and of the correct viscosity.
Sorry to hear of your troubles, good luck!
hummmmm????!
sure that aint some form of "tackifier" to stick the plates together when you hit the nitrous feed?
shanneba shanneba is offline
I too contacted Dave at Red Line before I used their product in my Sportster.
(I actually sent the same link where the product page says Sportster transmissions)
I was surprised they suggested the 75w-90 gear oil. I had expected either the MT-90 or 75w-90 NS(it does not have the limited slip additive) as what they would suggest. Dave did confirm that either of these would also work but they primarily suggest the 75w-90 gear lube.
I ran the MT-90 for 10,000 miles and I have the 75w-110 in it now. The 75w-110 is close to the same viscosity as HD Formula +.
I want to do a UOA again with the 75w-110 to see if the higher viscosity helps with wear. (My UOA for the trans/primary with MT-90 is posted here)
There is a technical document at Red Line's web site-
V-Twin Transmission Tech: A Better Idea Than Using Motor Oil in Your Transmission
The latest Sportster examples (2006-2009) are much improved in the gearbox department, as they no longer puff oil out the breathers. They'd better be, as its hard to check the transmission wear in later bikes—the "trap door" which you used for access is no longer around, so you have to split the cases to see inside. Important note: Red Line does not recommend running V-Twin Transmission Oil or Heavy Shockproof in a Sportster/Buell transmission. Always remember to warm up your bike before draining or changing the gear oil, since that ensures that you get the most complete flush out of the transmission.
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Old 12th November 2016
just throwing this out. I use mobil one syn gear oil. I use the lighter vis at first and then went to the heavier vis which caused shift issues, they say the heavier vis would cushion better and reduce noise but I went back to the lighter vis.
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
Why not just use the H-D Formula+?
ParrotHead's Avatar
I am the great Cornholio!
Other Motorcycle Year: 1974
That's what I run.
John Wayne - "The Shootist"
