Keep & Kill
04 883
Last Post: Brad
V.o.e.s
max maxwell (73), hdphil (72), nsc (70), Tomo (66), harleychic (64), MA1 (58), sportynut (55), baka1969 (52), m0trh3d (48), edgeofinsanity, eyecandycustoms (41), SquidAEH37 (34) |
21st December 2016
Posts: 181 Sportster/Buell Model: XLH 1200 S Sportster/Buell Year: 1999 Sportster/Buell Model #2: XR-1000 Sportster/Buell Year #2: 83 Other Motorcycle Model: RZV500R/R1 hybrid Other Motorcycle Year: 1984
my sunday driver...
for those days when i want to ride without blonde barbie...
99 XL1200s forks and shocks are a bolt on...
supertrapp stainless cans are a TIG on job to a set of used spare OEM mufflers that I plasma cut the guts out...
swing arm spools are just off the shelf stock...
steering damper is one I got from Steve Stortz and made a bracket to bolt to the upper engine mount...
http://goo.gl/photos/MFhsFhdfTVLTpLPc9
http://goo.gl/photos/MdoAPniuPKh9bYgKA
1999 1200 Sport, SE 7500 ignition, SE air filter, DynoJet , Cone Engineering 2:1 pipe, Storz Steering damper, Russel Mach 3 Stainless Lines, VROD 4 piston front calipers, Bates Baja tires, XR1200 perf shocks, forks and triples coming very soon...
1983 XR-1000S to XR-1000RX Project Build Thread
21st December 2016
Posts: 8,316 Sportster/Buell Model: Sportster 883►1200 Sportster/Buell Year: 1994
Here ya go.... Nice bike...
__o~~o__
IXL2Relax
Reference the Sportsterpedia
An XLForum collection of technical info & advice
21st December 2016
Bike Builder
Posts: 1,869 Sportster/Buell Model: XL1200 S/ sold Sportster/Buell Year: 1996 Other Motorcycle Model: Suzuki M109R/ totaled Other Motorcycle Year: 2008
On the Highway to Hell, no stop signs, no speed limits.......
21st December 2016
Posts: 298 Sportster/Buell Model: XR 1200 Sportster/Buell Year: 2009 Sportster/Buell Model #2: XR 1000 Sportster/Buell Year #2: 1983
Very nice, Well Done!!, the space between the top of the rear tire and the fender looks a little weird, how does it handle?
Regards
Roy
23rd December 2016
The bike of my dreams, wish it was mine.
27th December 2016
150/80 on rear of xr1000... new wheels tires and brakes
cause i needed new rubber and I had the wheels/tires/brakes leftover from another project
150/80 K591S rear on 16x3.5 DNA Rim
100/90 K591S front on 19z2.15 DNA rim
H-D (sunstar) semi floating rotors all round
also solid mounts for the bar risers... much better
front is bolt on
rear needs the funky xr-1000 captured seal/spacers replaced with std 1.25x0.75 bits
you also need to make a new wire lower chain guard or go without (i will bend one up and mount it to the swing arm spool rather than the axle
you will have to follow the link to see pics as I am not allowed to post pics..
https://goo.gl/photos/JuW8QzjMX53h7wyg9
Reason: add pics
27th December 2016
Originally Posted by 84rzv500r
No permission required to post pics - but you do need to HOST the pictures on another pic site (photobucket, etc.), then insert the [IMG] code into your posting here...
Or, track down the address of your pictures hosted on the Google site and use the Picture Icon  here to create the [IMG] code you need... Like this:
__o~~o__
IXL2Relax
28th December 2016
Regards
Roy
well its filled with a meaty 150/80 K591S now
very good.. raise the tail and drop the nose... flattracked from 1969 till 1975 then roadraced from 1983-2011
28th December 2016
XR 1000 pics updated -- thanks for the help
Reason: post nonblocked pic links
28th December 2016
