0 New member in MD
Last Post: Veeflys
0 Primary Oil INSANITY!
0 Newbie CV rebuild
Last Post: Matt Black
0 Ei
Last Post: cazz1000
0 Decman's Birtday
0 Turn signals
Last Post: bockstroker
Last Post: r4fthrs
0 Oil??
0 acc pump
Last Post: Armand
Old 10th January 2006
freakyt's Avatar
freakyt freakyt is offline
Sportster/Buell Model: Dyna Wide Glide
freakyt has disabled reputation
Default Threadlocker on brake fittings?
I'm installing a new front brake line on my bike, and I was wondering if I should use some kind of thread locker on the banjo bolt to line connections. It seems like it would be a good idea to use loctite 242 on there.
Anybody know?
Trout's Avatar
Trout Trout is offline
Sportster/Buell Model: XL1200
Other Motorcycle Model: XS650 Bobber
Other Motorcycle Year: 1979
Trout has disabled reputation
NO.
Absolutely no. Definately not required or recommended.
You don't want anything in the system that could contaminate your brake fluid.
You need to use new copper (or aluminum, or stock rubber/aluminum) washers and they will seal everything up just fine and will stay plenty tight.
pquirk's Avatar
pquirk pquirk is offline
Sportster/Buell Model: 883 XLC
Other Motorcycle Model: FXDWG
pquirk has a brilliant futurepquirk has a brilliant futurepquirk has a brilliant futurepquirk has a brilliant futurepquirk has a brilliant futurepquirk has a brilliant futurepquirk has a brilliant futurepquirk has a brilliant futurepquirk has a brilliant futurepquirk has a brilliant futurepquirk has a brilliant future
Yup, I agree. Take a close look at that banjo bolt. If you "picture" how it works you'll see that loctite would seep into the channel where the brake fluid lives when you tighten to the bolt. That's a bad thing.
And now, for something completely different.....
freakyt's Avatar
You make some good points. Glad I posted here before I tried something like that
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
Don't even attempt it i can see that banjo bolt breaking off later on
and creating more problems down the road.
RTFS
Ride That F'N Sportster!!
Old 11th January 2006
indyrednek's Avatar
indyrednek indyrednek is offline
Sportster/Buell Model: 883c
Sportster/Buell Model #2: Flyrite Rigid completed?
indyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the roughindyrednek is a jewel in the rough
One thing to remember.
Replace the washers when removing or replacing the lines.
It is needed to properly seal and hold the banjo bolts in place.
Old 26th January 2006
freakyt's Avatar
Ok, so on the subject of washers and banjo fittings, I know to use two washers where a banjo bolt mates to a banjo fitting (one on each side of the banjo fitting), but what about where the brake line screws onto the banjo fitting? Should I use a washer there too? If so, what size? 10mm?
pquirk's Avatar
I can't picture any place where a washer would be appropriate if you're making your own brake line. I guess it depends on your particular setup, but I'd say no. I'm kind of lazy and buy the premade ones though so I'm no expert on the issue.
indyrednek's Avatar
The fitting there should be a flare fitting. No washer needed/used.
freakyt's Avatar
Ok, I just got home and looked at my fittings, now I realize that was a stupid question . No place for a washer here.
Good news I have all of the parts for my front bakes now . Should be able to get 'er done tonight.
