0 Please help with muffler identification
Last Post: RKN
0 teflon buttons or circlips?
0 1985 Ironhead, help with dynatek 2000 install
Last Post: atengnr
0 Dreaded carb again
Last Post: VXDspud
0 Where To Get Free Air
0 I bought a Sportster last month, but I don't know what to do now, when it leaked the
0 Intake Seals
0 Piston melted
0 Bob The Chicken
10 Introduction
0 82 XLH in Arkaksas
0 Venhill cable
Last Post: 93trident
0 Help & advice needed
Last Post: Andy Hog
0 My 99 883 c
Last Post: 99-883-c
0 Electrical problems.
Last Post: Andy Hog
0 New to HD
Last Post: Tyler45
0 Cam followers have locked up internally. No movement at all. Why?
0 LED Headlight?
0 Anyone know who can shorten fork tubes?
Last Post: Whitewalls
0 changing from stock gas tank
Last Post: Edster
PlanB, Cuco6924 (75), 1200sporty (64), iron68 (50), LifesHarlequin (37), mattosm (36)
Old 18th March 2017
chevelle's Avatar
chevelle chevelle is offline
Sportster/Buell Year: 19**
Sportster/Buell Year #2: 1965
Default Keihin Andrews accelerator pump high flow cover
It looks to me Keihin made all these covers so any of the basic raw castings can have additional operations incorporated to be used in any of their many configurations.
The stock pump cover for non CV Harley carbs (2-2) (on right) uses the same passage for supply and pump shot.
The high flow cover uses seperate passage for supply and pump shot (4-2). It also contains a loose check ball in passage.
The stock cover is not easily owner modified to incorporate seperate passages and check ball (2-2).
The Keihin CV pump cover (4-1) (left in center photo) is a high flow cover just as the Andrews. The only difference is the (4-1) cover has an extra counterbore compared with stock non CV.
The CV cover is made with packing bore in cover.
The non CV is made with packing bore in bowl body.
Seems to me the CV (4-1) cover can be made to work in non CV if (2) square packing are used, one in cover and one in carb body.
Note: All orifices in covers are the same.
