Last Post: spitfirechopper
Last Post: 883openpipes
Last Post: Blowupster
0 Stock vs. Modified
Last Post: blindfredy
0 rethreadable?
Last Post: senseigreen
Last Post: mct496
Last Post: Jowniofownio
0 Intro from New England
0 Diagnostic help
8 Crankshaft Failure
0 Head gaskets.
Last Post: Fridge
Last Post: MatHormell
Last Post: Ben221
0 first harley- help!!
Old 19th April 2008
pipen pipen is offline
Sportster/Buell Year: 1991
pipen is an unknown quantity at this point
Default Crane Adjustable Pushrods for xl 1991
Hello, how many turns or flats do i have to do for adjust (.0416" ) ?
Old 20th April 2008
chrishajer's Avatar
Sportster/Buell Year: 1988
If you are looking to adjust .0416", I have no idea what to tell you.
If you want to preload the lifter .100" (which puts the stock lifter in the middle of the operating range), you need to know the number of threads per inch of the Crane pushrods you're using. Once you know that, you can determine how many turns to lengthen the pushrod to attain .100" in compression.
I seem to recall Crane Cams pushrods being 1mm thread pitch, which means one turn is .039". To get .100" preload, you need just less than 3 full turns. That gives you .118" preload, and when you tighten the lock nut, you lose a flat or two, which puts you very, very close to .100"
So, 3 turns, I believe, gives you proper preload on an Evo lifter with the valve completely closed and the pushrod first at zero lash. I would verify the thread pitch on the pushrods to make absolutely sure, before you go adjusting them based on my advice. Adjusting them improperly can damage your engine.
--Chris
Old 22nd April 2008
Thank you for your answers.
My tappets are Comp Cams V Thunder Hy-Rev and they want one turn adjust to 0416 or 1mm with Comp Cams pushrods.
But my pushrods are Crane and they say 3 turns. I drive now the engine with one turn adjust for safe and it sounds ok i think.
But is it right?
Old 28th April 2008
One full turn with Comp cams pushrod gives 0417"
And one turn with Cranes pushrods is 039"
