0 The country store
Last Post: lugster
Last Post: VaFish
0 headight housing
0 Diagnostic help
Last Post: lugster
Last Post: sevenyears of famine
Last Post: lugster
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: sdsbassist
Last Post: guitarfish
0 Speedometer Damage
0 new oil lines
Last Post: Screw Loose Dan
0 THE Trainspotting Thread
Last Post: lugster
Last Post: lugster
Last Post: 883openpipes
0 96 xl1200c turn signals help
0 Shop Trick of the Day: Proper Welding Techniques
Last Post: BILLETPROOF
0 first harley- help!!
Last Post: Joesdaddy
Last Post: Blowupster
0 oil cooler or not?
0 Intro from New England
Last Post: oreocat1
Old 16th June 2017
ginsport ginsport is offline
ginsport is an unknown quantity at this point
Default Quit on road
I just had a shiftdrum replaced by a local shop. On the way home the bike seemed to stall out 2-3 times, a (30 mile ride) but picked right back up after a 1/2 second.
I parked it and left it overnight, the next day went to start it and it fired right up, i took off and in about 500 ft it started acting like it lost spark in on cylinder,
I got it back home,running, with no blinkers,flashers,speedo,tach..
Now it is stone dead, i checked the battery and the connections are tight also it shows 12.3 on the meter
Help
Old 16th June 2017
The 1994 Wiring Harness and Battery are GROUNDED together & to the frame/engine at the LEFT UPPER REAR MOTOR MOUNT...
On the 2003 (likely 2001 as well) the Battery grounds on the RIGHT UPPER REAR MOTOR MOUNT...
That's where I would start looking...
Check your manual regarding replacing the battery cables (to see the location specified)...
Here's the Sportsterpedia section on Voltages & Grounds:
http://sportsterpedia.com/doku.php/t...place_to_start
The Battery Positive goes directly to the Starter solenoid (using the battery cable) and is then fed from the solenoid thru the MAIN CIRCUIT BREAKER to the Keyswitch (on the RED Wire)...
That's where I would look next...
IXL 2 Relax
>>>> My Build & Ride Reports Are Here <<<<
Reference the Sportsterpedia
An XLForum collection of technical info & advice
Old 16th June 2017
sportsterdoc's Avatar
Other Motorcycle Model: Honda CB1100
Other Motorcycle Year: 2014
Grounds could be the issue.
Not charging could be another possibility.
12.3 key on or key off?
If off, battery is more than 50% discharged.
Charge battery, fire it up and then measure voltage at 2K + RPM
Old 19th June 2017
It was the battery, put a new one in and it fires right up !
Next project is the exhaust gaskets , wish me luck
THX
Old 19th June 2017
You didn't mention it, but I hope you still checked your cables & grounds for corrosion, cracking, breaks and tightness... A prime opportunity when replacing your battery...
IXL 2 Relax
Old 19th June 2017
I did check them, they looked better than I thought
Thx
Old 19th June 2017
sportysrock's Avatar
Sportster/Buell Year: '96
Sportster/Buell Year #2: '72
But is the new one charging properly? If not, it will suffer the fate of the old battery.
Sent with :-)
Old 19th June 2017
What should my voltage be on the battery if it is charging correctly?
Old 20th June 2017
13.8v to 14.8v...
http://sportsterpedia.com/doku.php/t...ltage_readings
IXL 2 Relax
