0 Help with my clutch please
0 Lowboy frame conversion
0 C.O.B.B run west
Last Post: skien
Last Post: Bwf347
0 New 2017 H-D Street Rod XG750A
Last Post: Bone
0 Removing oil key from shaft
0 2003 1200 Custom riser
Last Post: ahusain
0 What's your helmet?
Last Post: The Crusher
0 Primary Oil INSANITY!
Last Post: ed_in_az
Old 16th June 2017
ironsights ironsights is offline
Sportster/Buell Model: 1200c
ironsights is a name known to allironsights is a name known to allironsights is a name known to allironsights is a name known to allironsights is a name known to allironsights is a name known to allironsights is a name known to allironsights is a name known to allironsights is a name known to allironsights is a name known to allironsights is a name known to all
Default Baffled By Brakes
I just bought my first Harley. It's a 2005 1200c and it only has 5000 miles. The rear pads are OK but the brakes were weak. I removed the pads, cleaned it all up and returned it all to orginal condition. Now I have no rear brakes. Nothing seems to be coming out of the master cylinder. It will not bleed anything but an eyedrop. I've read a few posts here and there about the rear MC problems so I removed it and took it apart. I have the service manual to guide me along and all went according to plan until the last step. For those of you with the service manual please look at the exploded diagram of the rear master. To my surprise I do not have parts 16 or 17? There is no spring or primary cup as the diagram shows. The piston was the last part that came out. There is still something rubber inside the main body. Have I misunderstood something or is there more than one rear master cylinder type for this model?
Nice to be here, Thx.
Old 16th June 2017
rocketmangb's Avatar
16 and 17 have to be in there for the brake to work
Could be stuck in the bore Iron
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 16th June 2017
I've never posted a pix before but I'll give it a try.
Old 16th June 2017
And your sure 16-17 aint stuck down the bore of the master ?
Old 16th June 2017
Well there's still something wedged in there... but I don't want to poke at it too hard if its rubber.
Like you say...Its gotta be there. I'll try to find something to ease it out.
Old 16th June 2017
It will be junk if its the primary cup.
Can you blow air pressure backwards through it from where the brake line banjo bolt screws in ?
Old 20th June 2017
Ya it was the primary and spring in the bore...They look good. No damage. I guess it'll have to go to the shop now which is a pain cause the shop is 200kms away.
Oh well.
Old 21st June 2017
Buy a rebuild kit please !
Old 21st June 2017
A rebuild kit? Even if everything looks good?
Old 21st June 2017
Master is a known issue from 04-06.
Ask yourself why the spring didnt push the cup out of the bore when you took it apart.
Look at the cup closely for a potential failure point in the future
