0 New member in MD
Last Post: Veeflys
0 Primary Oil INSANITY!
0 Newbie CV rebuild
Last Post: Matt Black
0 Ei
Last Post: cazz1000
0 Decman's Birtday
0 Turn signals
Last Post: bockstroker
Last Post: r4fthrs
0 Oil??
0 acc pump
Last Post: Armand
Old 17th July 2017
Alundrah Alundrah is offline
Sportster/Buell Model: Sportster xlh
Sportster/Buell Year: 1985
Alundrah is an unknown quantity at this point
Default Rocker gaskets
Okay I am putting some new james gaskets on my 85 ironhead and just want to run this past you all. After getting surfaces flush I applied yamabond to the head and placed the new gasket on there. I then put rocker cover on and evenly tightened it down. My thought is that I'll adhere first this side of the gasket and ler it set overnight. The 2mo I will remove rocker cover and apply yamabond to the cover and replace and tighten. I figure this way I have less chance of jostling the gasket around when I set the cover on. Does this sound objectional to anyone? I could have did both sides of gasket at once but I just didn't want it slip sliding too much as I push cover down into place. Also should would my first step of reassembling this bike to be putting the motor onto frame? Or should I atrach wire harness that runs along bottom of frame first? I know these are rookie questions, vut this is my first rebuild and do not want to take steps backward if I don't have to. Thanks for any help you may have. One way or the other, this bike is gonna be awesome when I finish!
