0 My last real nagging problem
0 N65C or N65A
0 check my chain?
Last Post: jcro61
0 Shotgun Porn
Last Post: robbie202
9 MAP code problems
0 Hillbilly Hot Dogs
Last Post: gravydog
0 Handlebar Question
Last Post: kluoto
0 Oil Pump upgrade
0 Removing powder coat?
Last Post: Oli1200
Last Post: ezmerf
0 new (to me) '82 25th Anniversary Edition XLH 1000
Last Post: eimkeith
0 Oil On Underside Of gas Tank
0 starting characteristics
Last Post: smac74
0 Replacement clutch discs
0 Sudden stiff rear brake pedal.
0 How dangerous is 2k clear coat really?
Last Post: Hugh Jasol
Last Post: spamer80
0 TC88A and Raptor shift light
0 Greetings from central Illinois
Last Post: 3dognate
0 Lost compression?
Last Post: frogg_nutts
0 Shop Arson
0 Thought my clutch went out or tranny, was front pulley
Last Post: kuri77
prbetts (71), 1988XL (67), jbcant (66), gearman (63), rejeanprimeau, Hdrider8831200 (57), AOW (50), adair727, Mechano (46), 64physhy, Buckshot (44)
Old 13th August 2017
swampig swampig is offline
Sportster/Buell Model: 1200c
swampig is an unknown quantity at this point
Smile wide glide small problems!!
hi guys finally getting round to chopping the sporty!! had some mid glide trees made 8.5 inch centres and need some advice on spacing wheel and getting a new axle made. Firstly, do i space the rotor or the caliper? what length of axle do i need i think it maybe 30mm over length but not sure! how do i go about spacing the wheel to centre it ? does it need to have any l/r offset? wheel is standard 21 inch
cheers guys
Swampig UK
[IMG]www.facebook.com/photo.php?fbid=10156508914533102&set=pb.611773101.-2207520000.1502609048.&type=3&theate[/IMG]
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
Well this is how I would do it.
1. You want the tire centered.
2. Place the wheel/tire on the axle with no spacers and place in the new frontend.
3. Center the tire and make measurements for the axle spacers. They may not be the same size because of hub offset.
4. Pick your caliper mount and use a hub/rotor spacer to bring the rotor out to the caliper position.
Old 15th August 2017
cheers Decman!!
