Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > FORUM FUNCTIONS > Sportsterpedia.com Admin
Sportsterpedia.com Admin For discussion regarding the administration of the Sportster Wiki.
Last Post: fafcpa
0 Cali Carb 1989 883
0 RSD Front Pulley Cover Install?
Last Post: cbzdel
0 Can you ID this bike?
Last Post: Bigshankhank
0 This place still sucks!!!
0 Can't clear unread messages
Last Post: Brad
0 Sportsters No More?
0 Rear shocks ?
Last Post: 83XLX
0 0Salt Flat Sporton
0 Cant find (2001 Jugs/Pistons On 2005 Engine?)
Last Post: thecarfarmer
0 Tire Pressure 1979 XLH
Last Post: Scuba10jdl
0 Rear Sprockets
Last Post: hbkeith
Last Post: Turbo Sporty 48
0 New Dakota Digital speedo/tach...
Last Post: TheBreeze
0 Chinese S&S carbs
Last Post: Serious Blac
0 Another Test In REAL Snow, More in-depth than...
0 Hard to find Neutral
4 Rear Lighting WIRING help
Last Post: jsaintmartin
0 DK Customs Air Intake
0 How many helmets?
Last Post: Marsikus
0 MagnaFlow Riot collector
Last Post: Conan
  #91
Old 13th February 2019
Hippysmack's Avatar
Great!
Thank you for that information!
Old 30th March 2019
shanneba shanneba is offline
Default Harley Type E fork oil
Great info on the Harley fork oil in the SportsterPedia!
Internet info seems to be all over the place on viscosity
I have some additional information I've found recently.
The HD parts/accessory web site in the Type E fork oil has an answer in the Q&A with the viscosity at 40 C / 100 F listed.
https://www.harley-davidson.com/stor...-17-9988480--1
Kinematic viscosity at 40°C [mm2/s = cSt] Mid-point.....Minimum.....Maximum ......46............... 41.4............. 50.6
ISO 3448 Viscosity class ISO VG 46
ISO VG 46 = SAE 15
Spectro also has a chart with HD Fork oil info:
http://www.spectro-oils.com/wp-conte...Data-Chart.pdf
Code:
|             PRODUCT               | WEIGHT  | VISCOSITY @ 100° C |
| Harley Type B                     | 10wt    | 5.51               |
| Harley Type E                     | 20wt    | 7.95               |
| Screaming Eagle Type Heavy        | 20wt    | 8.60               |
| Screaming Eagle Type Extra Heavy  | 60wt    | 24.49              |
| Spectro Type E                    | 20wt    | 7.93               |
| Spectro Type Heavy                | 40wt    | 13.06              |
I contacted Dave at Red Line about which Red Line fluid to use to replace HD Type E.
His reply:
the Harley type B is just slightly higher viscosity than the Medium, the type E is about 20% higher.
The mix ratio to match the HD type E viscosity at 100°F would be about 75% RL Medium and 25% RL Heavy Suspension Fluid.
I made a chart of the HD Type E (using the viscosity info I found), the RL 75/25 mix and the RL Medium and RL Heavy at viscosity at temps from 0 C (32 F) to 55 C (131 F).
I used the Widman calculators from here: (I used Firefox so I could enable Flash)
https://widman.biz/English/Calculators/Graph.html
I will probably send Blackstone a sample of HD Type E for analysis.
I will also request the viscosity at 100 F (40 C) to have actual data.
2013 XL1200C
Enter your VIN OR
SportsterPedia.com
Old 31st March 2019
Hippysmack's Avatar
The TDS / SDS info from the manufs is not even consistant.
This is the info I got from the HD website 3 years ago:
https://www.harley-davidson.com/store/fork-oil
Hey Hippysmack,
Technically the viscosity of the "B" and the "F" fork oils is proprietary info.
What I can tell you is that the weight for the "B" is between 0-10 and the "F" is between 5-20.
I'd take things with a grain of salt until it's tested.
That is interesting that the type E fork oil was answered, kinda.
Then the next answer is "we can't tell you that".
41.4-51.6 puts E in 15 ish wt class judging from other brands.
HD doesn't make the base oil. So, I vaguely compared 40C to others.
I'll add this to the narrative also.
I'd like to get the facts on type B and E.
You're right, all over the map depending on which manufs website you're on.
Me thinks there's an 'out of work' car salemen club that invaded the fork oil business.
Ours matches HD at .....
The chart is good, but it would be more useful with more of a variety of brands.
I'd like to see the Blackstone analysis of type E and B.
edit:
I'm trying to wind down, at least for now, the last big topic I had on my list.. noises.
I'll get back to this and the transmission bearings you posted next.
Thank you!
Old 31st March 2019
I did find a mention of Harley Davidson Fork oil type E on a Citgo web page but no information or SDS. It did indicate a 20W weight.
It also listed Harley Special Motor oil 20w-50, HD 240 / 360 10w-40, 20w-50, 50 and 60 and HD Special transmission oil.
https://www.citgolubes.com/lubes-advisor
Old 10th April 2019
I got the VOA of HD type E from Blackstone yesterday
I posted the data in the Suspension forum-
http://xlforum.net/forums/showpost.p...11&postcount=1
Old 10th April 2019
Hippysmack's Avatar
Thank you!
I'll compile this into the pedia also.
Old 13th May 2019
Larry May Larry May is offline
Sportster/Buell Year: 1968
Other Motorcycle Model: knucklehead
Other Motorcycle Year: 1936
Larry May has much to be proud ofLarry May has much to be proud ofLarry May has much to be proud ofLarry May has much to be proud ofLarry May has much to be proud ofLarry May has much to be proud ofLarry May has much to be proud ofLarry May has much to be proud ofLarry May has much to be proud ofLarry May has much to be proud ofLarry May has much to be proud of
I have an 82 XLHA that has the right case cracked or busted at the countershaft, I realize the cases have to be split to repair, who can do this, I would like to fix it since I also have the matching 82 XLSA, thanks for any help, advise, Larry
Old 13th May 2019
Hippysmack's Avatar
Larry,
I've seen that repair in threads on the forum.
But I'm not sure who to take it to.
A good welder obviously but I believe there may be considerations to be made when doing so.
If you'll post that question in the IH forum, I'll bet some of those guys can get you on the right path.
This is all we have in the Sportsterpedia on transmission case repair but it mainly deals with older cases.
http://sportsterpedia.com/doku.php/techtalk:ref:svcproc10?s[]=welding#trans_corner_reinforcement_54-_72
Old 13th May 2019
YEP...
>>>CLICK HERE<<<<<
Then start a new thread...
Old 10th July 2019
Bluto Bluto is offline
Other Motorcycle Model: Norton 850 Commando
Other Motorcycle Year: 1973
First off thanks much for the Sporsterpedia, a great resource. Did want to let you know of a minor error I spotted in the Evo forks section. It states that the drain screws are Phillips head and they are actually JIS and marked as such with a dot. It is very easy to strip the head of a JIS screw using a Phillips screwdriver and this has caused much grief working on Japan sourced bikes and parts. If you don't have JIS drivers in a pinch you can grind a bit off the tip of a Phillips driver or bit and it will fit a JIS screw much better.
some info from a blog (not mine)
https://wrenchandspanner.wordpress.c...s-vs-phillips/
