0 New From CA
0 Who Runs Turn Signals?
Last Post: vagrant318
Last Post: Martysf
0 Slip on muffler
Last Post: Tucsonmax1
0 FNG from OKC
0 New in NM
0 Stage 1 results
Last Post: 09Nightsterrider
0 Need advice (Falters When Turning Corners)
Last Post: Krjrcustom1
0 Spokes or Mags
0 -75 ironhead, My first HD
0 Riding on Blood Thinners
0 Touratech Destino Boots Review
Last Post: MotoMoshe
Old 24th April 2008
reblu's Avatar
reblu reblu is offline
Other Motorcycle Model: Suzuki Intruder
Other Motorcycle Year: 1987
reblu is just really nicereblu is just really nicereblu is just really nicereblu is just really nicereblu is just really nicereblu is just really nicereblu is just really nicereblu is just really nicereblu is just really nicereblu is just really nicereblu is just really nice
Default How do i check the rectifier/regulator please ?
This is my 1st problem with my sportster , the battery is dropping to flat after a few rides , i tried changing battery since my friend was'nt using his sporty and borrowed his but its the same thing , battery flat after a day or two .
I was wondering if the rectifier/regulator has died , how would i check that ?
Thanks in advance
Serg
Old 24th April 2008
QUICK WAY?
put a voltmeter across the battery terminals and note reading.
Then start and run the bike, note reading.
IF it's charging you should see 13-14 volts.
IF it's less than 12, then it's EITHER the voltage regulator OR the stator.
IF it's MORE, the voltage regulator is bad.
I'd need the manual to tell you how to check them specifically.
Old 24th April 2008
williamv1203's Avatar
williamv1203 williamv1203 is offline
Sportster/Buell Model: 1203 XLH/Buell Hybrid
Sportster/Buell Year: 1988
Other Motorcycle Model: FXDWG TC88
Other Motorcycle Year: 2000
williamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to behold
Cool
For AC output from stator:
Unplug the connector between the stator and regulator with bike running and use voltmeter into the two terminals from stator. You should have around a 18v push at 1000 rpm, if not, stator dead...
Also check for current draw with ign off, by using voltmeter on neg batt term (with neg cable off of it and pos still connected) and to a ground point on frame. If more than 1ma, there is a continuous current draw which is draining battery.
If it runs down during normal use, too many accessories putting strain on charging system. Do a load test. You will need specific load tester.
Old 24th April 2008
ColinB ColinB is offline
Sportster/Buell Model: 883R
ColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond reputeColinB has a reputation beyond repute
If you've got a battery tender pig-tail on your bike then you can make up one of these:-
It's a battery tender extension lead (cut back and wire-stripped), some heat-shrink and a couple of banana plugs () all soldered together. You can then easily plug your test meter into your battery and do the quick tests as described by Kev.
Old 24th April 2008
Fourcats's Avatar
Fourcats Fourcats is offline
Sportster/Buell Model: XLCustom 883
Sportster/Buell Year: 99
Fourcats will become famous soon enoughFourcats will become famous soon enoughFourcats will become famous soon enoughFourcats will become famous soon enoughFourcats will become famous soon enoughFourcats will become famous soon enough
Originally Posted by Kev M View Post
QUICK WAY?
Thats quick & simple ...beats throwing parts at the problem.
" flat after a day or two..." I would guess the battery is simply not holding the charge, needs replaced.
Old 26th April 2008
reblu's Avatar
Thanks to all , tried all you told me guys , seems my regulator/rectifier is dead !
Im gonna get one a.s.a.p !
