Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle - Bottom End
0 Ironheads
0 Salutations y'all
Last Post: Fridge
Last Post: Vohnsen
0 67 Sportster build
0 There’s shade tree brakes; then there’s the dark side of shade tree
Last Post: sdsbassist
Last Post: Grumpy-Biker
0 no rear brake light
Last Post: geoff
Last Post: goblin_dust
Old 26th April 2008
HarleyMan3529's Avatar
HarleyMan3529 HarleyMan3529 is offline
Sportster/Buell Model: XLD 883/1200
HarleyMan3529 is an unknown quantity at this point
Default All Metal Base Gaskets
I Am Trying To Find Out If Anyone Has Used The H-d All Metal Base Gaskets And If Anyone Has Had Trouble Getting Them To Seal. Mine Keep Leaking And I Have Checked The Torque.
Old 27th April 2008
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Welcome to the Forum!
Sorry, I don't know about the metal base gaskets.
You've posted both your posts in the 'Forum FAQ/HOW TO' section, which is for:
Facts, Answers, Questions, about the Sportster Forum and how to use the forum funtions
You may get more responses if you posted them in more appropriate Forum sections. Maybe
Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust
for the 'Oil Blow By' question, and
for this one?
Folkie
South East England Riders
Old 27th April 2008
Default Opps
Thanks brother, I am new at this
Old 28th April 2008
bplinson's Avatar
bplinson bplinson is offline
The XL Forum Host
Sportster/Buell Model: 883>1250 Stage 2
bplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond reputebplinson has a reputation beyond repute
Did you use any kind of sealant? When I did my 1250 upgrade NRHS sent me some white sealant. I can not recall what it was called though.
Might want to contact them and ask what they recommend.
AMA #961454
