0 Diagnostic help
Last Post: cotton1
0 headight housing
Last Post: Len PA
Last Post: MatHormell
0 Hope Cove, 20th May 2018
Last Post: Gamble Gold
0 A Day in the Life...
Last Post: cotton1
Last Post: cotton1
Last Post: 83XLX
Last Post: lugster
0 The country store
Last Post: lugster
Last Post: lugster
Last Post: sevenyears of famine
Last Post: lugster
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: sdsbassist
Last Post: guitarfish
0 Speedometer Damage
0 new oil lines
Last Post: Screw Loose Dan
0 THE Trainspotting Thread
Last Post: lugster
Last Post: lugster
Last Post: 883openpipes
0 96 xl1200c turn signals help
Old 26th April 2008
frogg_nutts's Avatar
frogg_nutts frogg_nutts is offline
Sportster/Buell Year: 72
Other Motorcycle Model: XLH
Other Motorcycle Year: 80
frogg_nutts is a jewel in the roughfrogg_nutts is a jewel in the roughfrogg_nutts is a jewel in the roughfrogg_nutts is a jewel in the roughfrogg_nutts is a jewel in the roughfrogg_nutts is a jewel in the roughfrogg_nutts is a jewel in the roughfrogg_nutts is a jewel in the roughfrogg_nutts is a jewel in the roughfrogg_nutts is a jewel in the roughfrogg_nutts is a jewel in the rough
Default Getting ready to install new 23T
Got my new gear in.. and free time this Sat eve!
Two questions,I remember reading a post about gear seals leaking..should I replace mine.(doesn't leak a drop now).And #2 My chain has less than 5K miles.
How often do Yall change Yours.(mines factory but looks great) 1974 XLH
Old 26th April 2008
I had a problem with the oil seal behind the front sprocket leaking. I replaced it 3 times before i found the actual problem.
The oil seal must be pushed well into the holder before it is installed. I assumed that the process of screwing the holder into place would push the seal in. For good measure i put a little Permatex Ultra Blue sealant in the holder; but this should not be necessary.
Old 26th April 2008
Good afternoon Mick!
Was this a result of Your changing out gears?
Old 27th April 2008
I miss worded as normal..meant to say,got my new gear in hand,lookin at Ironhead fixing to tear into it.
any words of wisdom.
Cc
Old 27th April 2008
noticed that my rear pipe is allful close to starter motor.when I wiggled it I see I must have a exhaust leak..it moved.Time for drag pipes?
Old 27th April 2008
I have 51/23. "Everyone" uses this combination or it's equivalent. Good acceleration. Significantly reduced vibes at hiway speeds.
I tried 49/23; was useless.
Old 27th April 2008
Thanks.
I was asking when You installed the 23t in Your 1980, is that what caused the leak..if so, I need to buy a new seal?
I'm half dyslexic..
Old 27th April 2008
Thanks.
I'm half dyslexic..
You do not need to remove the oil seal and the oil seal retainer to switch the sprockets. If it is not leaking then i would not replace it. I might have a new spare on hand tho.
The first time i replaced the front sprocket i needed a puller to remove the old one. On subsequent times it just came off easily.
Old 27th April 2008
K
Im going for it.
Donka
Old 29th April 2008
Yep,it took a puller. And the seal was just barley sealing..less than a 1/4 " the seal wasn't shoved in all the way into the holder from the factory. All good now, and I like the gearing! New tires/bearings and I guess Im good to go on trip!
