27th April 2008
Posts: 874 Sportster/Buell Model: XL1200R Sportster/Buell Year: 2006 Sportster/Buell Model #2: X1 Sportster/Buell Year #2: 1999
What pullback risers or t-bar to clear Peanut Tank on 06
If I were to try some risers with some pullback in them how tall would they need to be to clear the tank?
I will take measurements myself but it would be good to hear from those that have installed pull back risers or t-bars with the riser and pull back in the riser.
27th April 2008
Posts: 3,336 Sportster/Buell Model: 1200R 90+HP Sportster/Buell Year: 2004 Sportster/Buell Model #2: 2276cc VW sandrail Sportster/Buell Year #2: 1976
I just made some aluminum spacers 1 3/4" long and used longer 1/2" bolts to raise mine and tilted the bars back. No need to change any wires cables or brake lines that way.
27th April 2008
Posts: 550 Sportster/Buell Model: XL883-NRHS1212 Sportster/Buell Year: 2004
My bike had stock bars and 4 1/2" pullbacks when I got it, the stock style wire ties rubbed dull spots in the paint. The 4-1/2" risers combined with 27" drag bars had the controls hitting the tank and had the stock brake line in a pretty bad bind. The drag bars with 5-1/2" pullbacks have plenty of clearance.
There is no K in old school.
Zackleys
27th April 2008
Posts: 3,745 Sportster/Buell Model: 883R Sportster/Buell Year: 2007
I spent a bit of time trying to sort this out, and here's what I found:
Do 4½" pull-back risers clear an 883R tank..(yes)
Pictures of 4½" pull-back install...note the 'Xena Mod' (the wires and brake hose just touch on full lock).
There's enough slack in the wires and brake hose to add ½ - 1" spacers under the risers with ½ - 1" longer bolts if you want to later.
27th April 2008
Ride That F'N Sportster
Posts: 15,754 Sportster/Buell Model: Highly modified 1200 c Sportster/Buell Year: 01 Sportster/Buell Model #2: KX450F Other Motorcycle Model: FLHX H-D Street glide Other Motorcycle Year: 2013
With T-bars you can go minimum of 6".......... but i prefer to go with 8" overall to eliminate all tank clearance issues altogether........ you will have to lengthen the cables, wires to make 8" work from lock to lock!!
RTFS
Ride That F'N Sportster!!
27th April 2008
Posts: 15,243 Sportster/Buell Model: XLH-1208 Sportster/Buell Year: 1997
I Used 5 1/2" pullbacks and haven't had any issues, at all. The 4 1/2 seems to touch at lock. (or I get an weird bar angle)
States I've Ridden in
71.3 hp 70.8 tq
