0 Dreaded carb again
0 oil pump
Last Post: factory rat
0 Please help with muffler identification
Last Post: RKN
0 teflon buttons or circlips?
0 1985 Ironhead, help with dynatek 2000 install
Last Post: atengnr
0 Where To Get Free Air
0 I bought a Sportster last month, but I don't know what to do now, when it leaked the
0 Intake Seals
0 Piston melted
0 Bob The Chicken
10 Introduction
0 82 XLH in Arkaksas
0 Venhill cable
Last Post: 93trident
0 Help & advice needed
Last Post: Andy Hog
0 My 99 883 c
Last Post: 99-883-c
0 Electrical problems.
Last Post: Andy Hog
0 New to HD
Last Post: Tyler45
0 Cam followers have locked up internally. No movement at all. Why?
0 LED Headlight?
0 Anyone know who can shorten fork tubes?
Last Post: Whitewalls
PlanB, Cuco6924 (75), 1200sporty (64), iron68 (50), LifesHarlequin (37), mattosm (36)
Old 7th March 2018
Flam Flam is offline
Sportster/Buell Model: 1986 evo 1100 Liberty
Sportster/Buell Year: 1986
Flam is an unknown quantity at this point
Default andrews accelerator pump for Keihin Carb Butterfly
hi been searching online for the Andrews Accelerator pump
for the butterfly carb sportster without any luck
but I did find I think a variant( think ) by flow master v twin products
VTWIN 35-9050
http://vtwin.parts/supplier/v-twin/s...-9050?limit=50
is this similar to the Andrews ?
thanks
Old 7th March 2018
John Harper's Avatar
Sportster/Buell Model: 1250
Sportster/Buell Year: 1991
It's listed as out of stock. I thought you needed to replace the carb bowl to incorporate an accelerator pump, so that item pictured has somewhere to seat against. I could be wrong.
John
Old 7th March 2018
Edster's Avatar
Edster Edster is offline
Edster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant futureEdster has a brilliant future
Dennis Kirk used to carry them. You might check there.
Sent from my LG-TP260 using Tapatalk
Better to die on your feet than to live on your knees.
Old 7th March 2018
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
Flam, I sent you a PM...
Old 7th March 2018
83XLX's Avatar
John
The Keihin butterfly carb already has an accelerator pump, so the Andrews high-flow pump body just replaces the stock one on the bottom of the float bowl. You do have to drill a hole in the bottom of the float bowl to feed the new pump body, but it's easy to do.
Old 8th March 2018
Oldster Oldster is offline
Sportster/Buell Model: XLH1100
Sportster/Buell Year: 1987
Oldster is an unknown quantity at this point
You need a stock early Keihin accelerator pump cover, they changed them for EPA, but its the same thing. I don't have a number, but they were stock late 70's, early 80's. Probably some on eBay, that's where I got mine. Still have to drill the hole, though
Old 8th March 2018
BigMek's Avatar
BigMek BigMek is offline
Sportster/Buell Year: 1982
BigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond reputeBigMek has a reputation beyond repute
The part number is Andrews 269050. Some quick googling is showing it's out of stock all over the place, and it's no longer listed at JP Cycles or Denniskirk at all. That VTwin part has the Andrews part number listed in its description so it might be the same thing.
Edit: According to the VTwin website it's been discontinued and no replacement is listed.
Old 8th March 2018
Harley part number is 27364-76. One on eBay right now.
Old 29th April 2018
Best thing I’ve done so far
Old 30th April 2018
farmall farmall is offline
Sportster/Buell Year: 73
farmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond reputefarmall has a reputation beyond repute
It was a major improvement on every bike (mine and customers, big twins and Sportys) we did it to back in the proverbial day!
Also aim the pump nozzle to the center of the venturi if it doesn't squirt there already. It's a press fit. Just remove your air cleaner, open the choke, and give it a couple of squirts to see where to rotate it.
I put metric socket head screws on my bowl for convenient removal. There used to be kits but you can get matching sizes via Ebay in stainless for cheap from China.
