41caninek1 (80), InkyDoggy (70), shepsvettes (68), outlw (49), outlaw05 (49), bklyngeezer (48), Skinn (47), theguy35 (42), IronHound (42), 2013iron883 (40), huge_midgit (34) |
9th March 2018
Posts: 22,249 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2006 Sportster/Buell Model #2: XL1200C Sportster/Buell Year #2: 2006 Other Motorcycle Model: 48 "Totalled" By a Douche Other Motorcycle Year: 2012
HD Super Premium 5 vs Napa 7148 5 micron oil filter
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
9th March 2018
Posts: 486 Sportster/Buell Model: 883 custom Sportster/Buell Year: 2006
Obviously built to a HD price point...
Joe
9th March 2018
Posts: 2,425 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2013
Looks likes it is made by WIX- should be a good filter for Sportsters.
NAPA Filter:
Code:
Part Number: 7148
UPC Number: 765809235663
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Synthetic
Height: 3.404 (86)*
Outer Diameter Top: 2.921 (74)*
Outer Diameter Bottom: Closed:
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=6/20
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 5
The beta ratio indicates it filters 50% at 6 microns and 95% at 20 microns.
WIX 57348 Chrome 57148 Black Data :
Code:
WIX Part Number: 57348
UPC Number: 765809573482
Service: Lube
Type: Full Flow
Media: Synthetic
Height: 3.404 (86)*
Thread Size: 3/4-16
I am currently running the HD SuperPremium 5 and hope to have a UOA / particle count later this year  I'll either run another HD 5 micron or try a WIX next.
9th March 2018
Posts: 15,533 Sportster/Buell Model: XLH-1208 Sportster/Buell Year: 1997
Looks like the HD filter offers more media material to filter with.
States I've Ridden in
71.3 hp 70.8 tq
9th March 2018
Master Bike Builder
Posts: 2,070 Sportster/Buell Model: XL1200CP Sportster/Buell Year: 2015 Sportster/Buell Model #2: XLH1200 (traded in) Sportster/Buell Year #2: 1998
I need help. I'm sure rocketmangb's pictures are self-explanatory to many, if not most, on XLF. I can see differences between the Harley and the NAPA (aka Wix) filter. I don't know enough to say what makes one better than the other.
jzink0883, '15 XL1200CP, it ain't butt jewelry, it's a ride
9th March 2018
the larger media will typically mean more filtration, and with more holes in the intake, will allow for larger flow or a less restricted flow. Looks like the Napa filter uses a spring to hold the rubber diaphram against the inlet, where the hd filter is larger and doesn't need the spring at the top, but uses a small piece of metal at the bottom to lift the element off the filter housing.
9th March 2018
Master Bike Builder
ReddTigger,
I know that oil-filter threads can be like oil threads.
I noticed the differences that you cite. The online prices for the H-D, NAPA, and Wix filters are about the same.
Question: Is there a compelling reason for me to not continue buying the H-D filter?
9th March 2018
Posts: 1,962 Sportster/Buell Model: XL1200R Sportster/Buell Year: 2004
Is there a bypass in the hd filter? Is that what the spring is for?
9th March 2018
Both have the top bypass.
Meaning if the filter does bypass it just runs across the top of the filter unlike the old filters which had a bottom bypass (many still do) which would wash the crap out of the media right in to the engine.
9th March 2018
Posts: 937 Sportster/Buell Model: Sportster Superlow 1250 Sportster/Buell Year: 2014
The Harley Davidson filter is working just fine for me so I will continue using them. I do have a filter magnet I used to use on my truck filter. I believe it will fit the Harley filter. I may put it on and see what happens.
2014 Sportster Superlow, Hammer 1250, smash head work, 560 cams, S&S rockers and lifters. ported throttle body and intake,
Hammer crush air cleaner, Barnett clutch
Tuned by Power Vision
Supertrapp Supermegs exhaust
1200 gearing, super brace
Progressive suspension front & rear
